Date/Time: Sat, 01 Feb 2025 16:54:05 +0000
Bid/Ask Volume not Accurate for CQG data feed.
View Count: 752
[2019-07-26 05:06:19] |
User600284 - Posts: 9 |
Hi, I have noticed that my cumulative delta chart is way off with out of ordinary volume prints. I verified with CQG and it's not their data issues. Could you tell me how to trouble shoot this issue? I have attached a few screen shots of the charts and T&S data of the chart from edit>export bar data to text file function. Please note that whenever I have issue with delta jumping on CD study and chart bar missing is that there are 260 volume (either bid or ask) and my chart is 260 volume per bar chart. Thank you in advance. http://www.sierrachart.com/image.php?Image=1564117362261.png |
[2019-07-26 18:41:19] |
Post an image of the chart itself by following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Not of the entire Sierra Chart window. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
