Date/Time: Sat, 01 Feb 2025 15:54:06 +0000
Spreadsheet Study Excel selected
View Count: 540
[2019-07-26 03:17:43] |
Joshua Dawson - Posts: 5 |
I am new to using Sierra charts and still in the learning curve. When I export data using the spreadsheet study with the Excel feature on, I get around 13 sheets that are blank. Sheet number 2 has the correct data but is missing the Date Timestamps, I need that info for Time-series analysis. How do I fix this so it is only one sheet with the correct Date and Time? As of now I do not have any Date time data using the Excel feature? However, when I use the spreadsheet study without Excel on, everything works smoothly. I just don't know how to get it into Excel without copying and pasting. Thanks for the help. |
[2019-07-26 04:26:46] |
We do not provide support for the "Use Excel" option and it is getting removed this year. Please do not put any reliance on it as it is getting removed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 04:26:56
