Date/Time: Sat, 01 Feb 2025 15:44:50 +0000
why the trade activity log can only show up to mid-2016
View Count: 639
[2019-07-26 00:37:48]
user - Posts: 78
i downloaded data from 2013 to 2019, and run the "autotrade system bar based backtest". I can see the signal in/out on the chart. However when I open the trade activity log, it can only shows the latest 3 years data!!
How can I know the result beyond 3 years?
[2019-07-26 04:53:18]
And did you set the Date Range to Display >> From within the Trade Activity Log back to 2013?
You also have to make sure that you are actually looking at the order fills on the chart:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2019-07-26 05:31:22]
user - Posts: 78
ok, I need to type the date instead of just select in the pulldown menu.....
Thanks!
[2019-07-26 05:51:37]
Yes!
