Date/Time: Sun, 24 Nov 2024 20:23:19 +0000
unhandled exception messages
View Count: 1060
[2013-12-04 21:53:55]
Atlatyl - Posts: 19
I am getting these unhandled exception messages routinely over the last week...on both the current and the last version of the software...forces me to shut down the chartbook..it is not specific to any particular chartbook or charts...nothing has changed on my computer...been running sierra charts for years. Seems to happen randomly...not good while trading : / Restart doesn’t help. Running XP, pentium D CPU 2.80 GHz (2 CPUs)..1022MB RAM....help?
attachmentsierra.bmp - Attached On 2013-12-04 21:47:21 UTC - Size: 873.56 KB - 514 views
[2013-12-04 22:56:05]
Are you running any custom studies?
If so, could you refer to help topic 17:
http://www.sierrachart.com/index.php?l=doc/helpdetails17.html#h17.1
If you still need help please attach your Chartbook. It can be attached privately so only we can view it. We will test the Chartbook. Here are the instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
