Date/Time: Tue, 29 Sep 2026 23:25:46 +0000
Build error with SC compiler not with Visual Studio
View Count: 1234
| [2019-07-25 17:32:26] |
| User470516 - Posts: 78 |
Dear SC team, I have developped an ACSIL study and a "functions.cpp" code that contains my own functions code, I have created the associated header file ($functions.h") which is properly included where it should. When I compile my study with Visual Studio 2019, compilation works and my study works. However when I try to do the same with the remote build provided by SC, I get the following error: The remote build did not succeed. Result: $functions.cpp:2:24: fatal error: $functions.h: No such file or directory #include "$functions.h" Could you please tell me what I could be doing wrong? The header file is where it should in the ACS_Source folder. Thank you, Laurent |
| [2019-07-26 06:55:26] |
Refer to the documentation here for this: Advanced Custom Study Interface and Language (ACSIL): Using Your Own Header Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
