Date/Time: Sat, 01 Feb 2025 16:00:59 +0000
Making the switch from CQG(AMP) to SC Denali feed
View Count: 1162
[2019-07-25 16:17:53] |
User266069 - Posts: 30 |
Hi SC team, Im with AMP, and since reading you guys will start offering HKFE to people in HK starting from August Ive decided to use SC Denali feed. My question is within AMP Living trading platform setup, which one do I choose to make the switch? SC - CQG SC - Rithmic SC - CTS - T4 Also, if i made the switch, would I still be able to use the free SC package offered by AMP? Im probably missing some details here since I have no experience in living trading yet and only plan to do so starting in August, if so please let me know |
[2019-07-25 18:19:44] |
If you want to use the Hong Kong futures exchange it is necessary to use the Sierra Chart Exchange Data Feed which is a different feed from the Denali Exchange Data Feed. Refer to: Sierra Chart Exchange Data Feed If you want to trade Hong Kong futures you would need to use CQG if you are with AMP: CQG Trading Platform Service Also, if i made the switch, would I still be able to use the free SC package offered by AMP? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-25 18:20:57
