Date/Time: Sat, 01 Feb 2025 15:56:06 +0000
Number Bars bid ask min volume
View Count: 1125
[2019-07-25 15:33:25]
User370349 - Posts: 1
On Number Bars, Bid Ask Minimum Volume (Line 95) has no effect when Background Coloring (Line 18) is Based on Dominant Ask Volume Bid Volume to Volume at Price Percentage.
[2019-07-25 22:23:04]
John - SC Support - Posts: 37656
We have added in the check for the Bid/Ask Minimum Volume Compare Threshold when using the Background or Text coloring of Dominant BidVol/AskVol to Volume at Price Percentage. Note that as stated in the documentation for this setting, both the Bid AND Ask values have to be less than or equal to this Input for the comparison to not take place. If either one exceeds the setting, then the comparison will still occur.
This will be in the next Pre-Release (v 1959). When available, you can update using the Fast Update option:
