Date/Time: Sat, 01 Feb 2025 15:55:37 +0000
FX quotes stopped working
View Count: 528
[2019-07-25 15:15:38]
rhovega - Posts: 279
FX tickers stopped updating on the quoteboard.
It's been a few days.
Wonder if you are aware of it and planning to fix it.
[2019-07-25 17:55:44]
The problem is if you are running a version earlier than 1600 you need to update to a newer version. Follow the instructions here to update:
And no this is not anything that is going to change. You need to update.
