Date/Time: Sat, 01 Feb 2025 16:02:41 +0000
BitMex Dual Login
View Count: 967
[2019-07-25 14:15:20] |
User78442 - Posts: 260 |
Is it possible to login on a second machine using the same BitMex Trading login?
[2019-07-26 01:14:37] |
From a Sierra Chart perspective, this is not a problem. Your account allows you to have Sierra Chart running on 2 different systems at the same time. You can also pay for more systems. You just need to make sure with BitMex you generate a second API key and use that in your other copy of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 01:14:50
[2019-07-26 03:50:06] |
Great!
