Date/Time: Sat, 01 Feb 2025 15:53:11 +0000
Trade order rejected retry
View Count: 984
[2019-07-25 02:28:53] |
feifei786 - Posts: 6 |
Hello, I'm getting the "New order rejected"x3 due to Bitmex overload, is there anyway to configure SC trading system to keep trying order until order successful? I checked documentation but couldn't find any. Thanks. |
[2019-07-25 04:32:37] |
No, this is not regarded as safe. It is not something we would add.
[2019-07-25 04:50:25] |
Okay, what if i want to delay the alert for 1 min? (i'm using alert base trading system) Is there anyway to do that? |
[2019-07-25 18:25:56] |
What do you mean by delay the alert? We are not understanding this.
[2019-07-26 00:27:42] |
Sorry for my bad english, let me rephrase. My SC trade alert only at bar close, but bitmex high probability overload at bar close, hence high probability trade reject. So is it possible to delay SC summit new trade order to bitmex 1 minute after alert? |
[2019-07-26 05:26:06] |
You really have to develop this using ACSIL: Advanced Custom Study Interface and Language (ACSIL) So the alert will need to be implemented using ACSIL and then you could submit the order after a delay. You could also check to see that the status went to an error state and that the Position Quantity has not changed. This can be a signal to retry sending the order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
