Date/Time: Sat, 01 Feb 2025 15:51:10 +0000
Zero Line added to Indicator
View Count: 2003
[2019-07-25 01:50:25] |
Gustavo - Posts: 74 |
Is there a way to add a zero line to the Force Index Average indicator? I've tried adding the line indicator (which I have used successfully to add a zero line to other indicators ), but for some reason will not work for me on the Force Index Average. Your feedback will be appreciated. |
[2019-07-25 23:31:48] |
You should not have any problem adding the Line study to same region as the Force Index Average study and setting the line to a value of 0. We have verified this works without any issue. Make sure the Scale Range of both studies are set to Automatic: Chart Scale and Scale Adjusting Try doing this with a clean chart with nothing but these two studies added to the chart and see if you have an issue. Make sure no other studies are included in the same Chart Region. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
