Date/Time: Sat, 01 Feb 2025 16:04:06 +0000
TD Ameritrade and Proper Exchange Fee Rate
View Count: 1230
[2019-07-25 01:05:58] |
User995659 - Posts: 2 |
I just need clarification on what Exchange Fee I should be on. I currently have selected No futures account and am on the $42 plan for CME (ES). I actually trade futures and have an open account with TDAmeritrade but know they don't support Sierra for futures. Therefore, I chose the $42 plan. I need access to NYMEX, COMEX and CME and see that as a package for $15.75/trading account required. Am I good to sign up for that feed since I do have a futures account but will not integrate through TDAmeritrade?
[2019-07-25 23:28:59] |
TD Ameritrade will work as the funded trading account allowing you to select the lower priced CME fees, as long as you are not seen as a professional trader and as long as you have at least $500 in your account with them. Therefore, go back and select TD Ameritrade for your Futures Broker. Then deactivate the CME E-mini, For professionals and users without a trading account exchange, and activate the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts exchange. You can access these options here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures And connect to your Ameritrade account once a month: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-25 23:46:31] |
Thank you the thorough and prompt response. It's very much appreciated.
