Date/Time: Mon, 03 Mar 2025 20:31:55 +0000
Chart Zoom state ACSIL
View Count: 997
[2019-07-24 11:36:03]
User907968 - Posts: 833
In ACSIL, is there a quick way to find out if the chart zoom tool (Tools->Zoom In) has been applied to a chart?
I has a look at the functions and in sierrachart.h but did not see anything obvious.
[2019-07-24 18:08:44]
No, this is not supported. Did you require this?
[2019-07-24 18:41:07]
Ok, no problem.
I was looking for a simple way to stop recalculation of studies based on visible range when the chart zoom tool is used.
So, it would be nice to have, yes, but if not I can probably work around it.
Thanks.
[2019-07-28 01:57:55]
We will add this.
[2019-07-30 06:54:35]
Thank you for adding this to the latest version.
Appreciate your efforts guys!
