Date/Time: Thu, 06 Mar 2025 16:37:11 +0000
Inquiry about point of control in number bars
View Count: 777
[2019-07-24 09:13:30]
User14410 - Posts: 38
Is it possible to set second / third or even more point of control display for each number bars? Thank you very much.
[2019-07-24 10:30:09]
Effectively what you want to do is use this particular Coloring Method for the Background or Text:
Numbers Bars: Background Coloring Based on Volume Percentage
You can specify the different percentage thresholds, and use different colors.
[2019-07-25 23:11:55]
According to your reference, I was unable to set the number bar to automatically detect for the first , second and third point of control for a particular number bar, as the % threshold is arbitrary and could not suit well... Is there an alternative approach suggest? Thank you.
[2019-07-26 00:00:29]
No, there is not an alternative. What we gave was the closest available.
Date Time Of Last Edit: 2019-07-26 00:00:38
