Date/Time: Tue, 23 Apr 2024 16:55:41 +0000
Sent log from Sierra chart installer
View Count: 698
[2019-07-23 14:33:21] |
Matt654 - Posts: 73 |
Having trouble up dating Sierra charts on some of my computers, one computer is okay. 2nd computer one package running, 2nd package has some sort of virus it has no working studies showing (This is the one I sent the log to you from chart installer) Then I have a laptop running on old XP Windows, which I use old software on. But your new version will not download to it. |
[2019-07-23 16:56:25] |
2nd package has some sort of virus it has no working studies showing (This is the one I sent the log to you from chart installer) Refer to:Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected Windows XP is no longer supported. We will look for your installer log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-23 17:05:20] |
You are not installing Sierra Chart into the correct location on your system. Install it into: C:\SierraChart Set the Installation Folder to that when you run the installer: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-23 17:05:36
[2019-07-24 18:25:04] |
Hi Support have solved the Virus problem thanks. Since the update I am having a problem adjusting the appearance of the P&F stems. In the sub-graphs section they are set 3-1-1-3. I want to set them 9-3-3-9, but soon as I press apply button they go back to 3-1-1-3. Any suggestions. |
[2019-07-24 18:30:28] |
What do those numbers represent?
[2019-07-25 08:47:37] |
Are you sure, Right go to Studies/ P&F settings/ Subgraphs and the numbers 3,1,1,3 should be right in front of you. I want to change them to 9,3,3,9. as they were before the update.
[2019-07-26 04:54:16] |
We assume you are referring to the Width settings for the first 4 subgraphs. As such, if you are using the P&F OHLC bars, rather than the P&F X-O columns, then the controls for the graphics settings for the OHLC bars is through the Global Settings. In this case, you will want to go to Chart >> Graphics Settings - Chart for this particular chart and then uncheck the option for Use Global Graphics Settings instead of These Settings. Then set the particular graphics settings as you want for this chart. The four options you want are the following: - Bar High-Low Down - Bar High-Low Up - Bar Open - Bar Close Refer to the following for more information on adjusting Graphics Settings: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-29 20:36:24] |
Hi Support have tried your suggestions and they still won't change like they used to before the update. Have any other suggestions.
[2019-07-29 22:30:32] |
John - SC Support - Posts: 31044 |
When you say they will not update, we do not know if you mean through the Graphics Settings or the Subgraph settings? If you are trying to change them from the Subgraph settings, this will not work. For quite awhile now, you have to change the settings for the P&F OHLC bars in the Graphics settings. Refer to the documentation here on this: Color Settings for Graph Draw Types: Point and Figure OHLC Bars If you are having trouble doing this via the Graphics Settings, then most likely you are trying to change the settings by selecting Chart >> Graphics Settings, but you have not disabled the option for Use Global Graphics Settings instead of These Settings. Refer to the section here on this: Graphics Settings: Use Global Graphics Settings Instead of These Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-30 09:46:22] |
Okay I'll have to do that later, I've been running 5 copies of Sierra charts for years now, have you switched off the feed to the 5th copy as it won't update real time, but its showing green for connected to feed. I seemed to remember there was problem about this before. Updating to the 1957 model Sierra Charts has cost me a lot of time and money, as had to buy another laptop as the old one was running XP windows. Its been over a week now and I'm still not back normal. |
[2019-07-30 15:05:43] |
Ah! its okay we are up and running, the wifi on the new laptop had automatically disconnected itself, thats the reason the charts were not updating.
