Date/Time: Sat, 03 Oct 2026 02:26:36 +0000
Chart Distortion
View Count: 918
| [2019-07-23 13:59:28] |
| User343799 - Posts: 1 |
Hello, We noticed chart distortion over the last month. Not sure what it is happening. Happens only with the ES. http://www.sierrachart.com/image.php?Image=1563890075995.png Please advise. Thanks, David |
| [2019-07-23 17:01:42] |
You need to remove all studies from that chart. And post the image again. We cannot make any sense out of it. Follow the instructions here: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-23 17:01:57
