Date/Time: Sat, 01 Feb 2025 15:02:28 +0000
Graphic Settings
View Count: 544
[2019-07-22 22:32:36] |
User43523 - Posts: 3 |
Now I'm trying to change the up/down bar colors. When I apply the new colors via Graphics/settings/chart I have to uncheck "use global graphics settings" to apply the new colors. But when I do that it changes the text on the chart and makes it HUGE. SO how do I just change the bar color and leave everything else the same as it was? Thanks, Kenneth |
[2019-07-23 05:08:36] |
You also need to adjust the fonts sizes as well. This can be done through the Fonts tab of the Graphics Settings window.
