Date/Time: Sat, 01 Feb 2025 14:55:51 +0000
[Programming Help] - Python wrapper
View Count: 3849
[2019-07-22 17:18:11]
User925659 - Posts: 39
Hey,
I cannot code in the C languages. I am really efficient in python. Is there a wrapper that I could use to take my python algos and backtest and wrap them into a c++ language that would allow sierra charts to do the functions I want automatically? Something similar to Cython? Or can I just use Cython?
[2019-07-22 17:48:37]
We do not think using the C/C++ language is going to be difficult. We explain this here:
Advanced Custom Study Interface and Language (ACSIL)
In regards to your question, we do not recommend using a compiler other than what is used through Remote Build, or the Visual C++ compiler.
Date Time Of Last Edit: 2019-07-22 17:48:56
[2019-07-22 21:32:37]
John - SC Support - Posts: 37656
Take a look at this thread and see if it helps you:
Python for Sierra Chart
