Date/Time: Fri, 29 Mar 2024 08:23:44 +0000
Trade Simulation
View Count: 577
[2019-07-22 16:39:40] |
User714212 - Posts: 2 |
Hi, I have a connection now through my broker which works fine. However, on the Sierra Chart simulator I have an issue with the tick value: the normal S&P500 Emini futures tick value per contract is USD12.50. In the simulator however it is just USD0.50. Can you please explain that and tell me where to change it. Thank you |
[2019-07-22 16:54:25] |
We are not sure where you are seeing that. Let us know. However, in general refer to this page about this: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-22 18:28:41] |
The attached screenshot has 5 lots short, 2 ticks offsite, USD0.25 per tick: 5 x 2 x 0.25 = 2.50 (apologies I mentioned before it is USD0.50 per tick and lot but it is USD0.25). I didnt find a way to change that. Let me know please. Thanks Louis |
Capture.JPG / V - Attached On 2019-07-22 18:18:09 UTC - Size: 103.28 KB - 248 views Attachment Deleted. |
[2019-07-23 17:40:12] |
You can use different formats. Refer to this setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-23 17:40:20
