Date/Time: Sat, 01 Feb 2025 15:47:12 +0000
Standard Error Bands Source Code
View Count: 564
[2019-07-22 08:56:29] |
tllh2210 - Posts: 1 |
I have been browsing documentation and searching "SCStudyFunctions.cpp" file for drawing of top/bottom lines for Standard Error bands studies. I am struggling to find the source code that draws the top and bottom Standard Error band lines. I did find the source code for drawing top and bottom lines for Keltner Channel in rows 799 to 808 in the "SCStudyFunctions.cpp" file but NOT for Standard Error Bands. Appreciate your guidance. Thank you |
[2019-07-22 09:09:35] |
Refer to scsf_StandardErrorBands in /ACS_Source/Studies3.cpp. Also look in /ACS_Source/SCStudyFunctions.cpp. The function name is GetStandardError. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
