Date/Time: Tue, 22 Apr 2025 10:35:35 +0000
Req: DOM & Time and Sales Attached
View Count: 1601
[2019-07-22 06:32:15] |
User735587 - Posts: 21 |
Hello, The DOM and Time and sales represent 2 different windows. Is it possible to attach the T&S to the DOM so that if you move the DOM window around, the T&S moves with it? Regards |
[2019-07-22 17:50:22] |
No, this is not supported. But longer term we will look at something like this functionality.
[2020-04-15 05:32:15] |
kremat0r - Posts: 47 |
+1 from me. It will be very useful to make it as one window, really please consider it. It's really frustrating many times :( Next thing about T&S is to put a "filter" or something to hide a part of price like YEN you have 0.0093550 price or for ES 2826.25 to see only last digits. Maybe picture will tell you more. Now I can make a column smaller from right side which will hide the most crucial part of price which changes very often, normally I need for ES last 4 digits like 2826.25 to know what price is doing. So it will be enough to allow to make column smaller but from LEFT side to hide the beginning of price. For YEN problem is bigger, because price has more digits, and my T&S column is big as hell. Next thing I think there is some "bug" in sierra related to T&S, look to the picture "2". There is a T&S window with "show title bar" unchecked but window look like it have title bar, it happen after closing sierrachart. I need to check and uncheck it every time after restarting sierra to have it back without title bar. Thanks :) |
[2020-04-17 05:32:48] |
I update to newest version and problem described above with T&S, still exists. Thanks. |
[2020-04-27 11:34:28] |
We will solve this.
[2020-04-27 20:21:34] |
We cannot reproduce this problem: Next thing I think there is some "bug" in sierra related to T&S, look to the picture "2". There is a T&S window with "show title bar" unchecked but window look like it have title bar, it happen after closing sierrachart. I need to check and uncheck it every time after restarting sierra to have it back without title bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-28 11:12:40] |
Problem still exist. I change pc and install sierra one more time. I can record by OBS how this problem looks like. Will be oK? About post #2 is there any updates with this? Date Time Of Last Edit: 2020-05-28 11:13:36
[2020-05-28 21:11:25] |
Ok you can provide a video. Regarding post #2, as we redevelop the dialog windows in Sierra Chart accomplishing something like this will be easier. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-29 11:53:04] |
User977098 - Posts: 28 |
Any update on the original question from this thread? This would indeed be a handy feature.
[2023-03-02 20:24:47] |
3years later. Is there any news here? This is long looking feature. |
[2023-03-02 22:29:30] |
As stated in post #8, nothing will be done with this until we get our new windows finished. The Settings Windows have been done, but there is more work to do to finish up the task. We do not know when this will be.
[2023-03-06 13:53:30] |
Thank you. I hope it will be soon.
