Date/Time: Thu, 06 Mar 2025 15:42:19 +0000
Scale on right of main chart
View Count: 745
[2019-07-22 06:10:14] |
User27542 - Posts: 20 |
Sorry to trouble you again, but the scale on the right side of the main price chart is only displaying to two decimal places. This means that the chart calculator tool also only displays to two decimals. I would like three or more. How can I fix that? With thanks for any help you can give.
[2019-07-22 19:47:58] |
You need to adjust the Price Display Format setting for the chart: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-22 19:48:52
