Date/Time: Sat, 01 Feb 2025 15:58:39 +0000
Rithmic Data Feed not connect
View Count: 1070
[2019-07-21 22:20:40]
User693573 - Posts: 8
I got the demo version of the sierra chart. I also got a demo data feed from Rithmic. Songs I can not get a connection to stand. Enclosed the log
Best regards
Robert Ulrich
Reading Internal Order ID file. | 2019-07-22 00:00:31.799
Reading Trade Orders file. | 2019-07-22 00:00:32.004
Reading Trade Positions file. | 2019-07-22 00:00:32.005
Reading Account Balance file. | 2019-07-22 00:00:32.006
Using Bid/Ask average for last trade price for EURUSD | 2019-07-22 00:00:32.007
UDPListener (1392). Port 22904 | Listening on UDP port 22904. | 2019-07-22 00:00:32.047
Software version: 1952 32-bit | 2019-07-22 00:00:32.047
Usage end date: 2019-08-03 | 2019-07-22 00:00:32.047
Enabled for: Advanced Features 2. | 2019-07-22 00:00:32.047
Enabled for: Sierra Chart Historical Data Service. | 2019-07-22 00:00:32.047
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-07-22 00:00:32.047
Current selected Data/Trading service: Rithmic Trading | 2019-07-22 00:00:32.047
Custom symbol settings values: enabled | 2019-07-22 00:00:32.047
Chart Update Interval: 500 | 2019-07-22 00:00:32.047
Intraday Data Storage Time Unit: 0 | 2019-07-22 00:00:32.047
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2019-07-22 00:00:32.047
2019-07-22 00:00:32 Local computer time | 2019-07-22 00:00:32.047
2019-07-21 22:00:32 Local computer time in UTC | 2019-07-22 00:00:32.047
2019-07-22 00:00:32 Local computer time in SC Time Zone | 2019-07-22 00:00:32.047
2019-07-21 22:00:32 Server time in UTC | 2019-07-22 00:00:32.047
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-07-22 00:00:32.047
Program path: C:\SierraChart\ | 2019-07-22 00:00:32.047
Data Files path: C:\SierraChart\Data\ | 2019-07-22 00:00:32.047
OS Version Number: 10.0 | 2019-07-22 00:00:32.047
Locale Setting: C | 2019-07-22 00:00:32.047
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-07-22 00:00:32.047
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-07-22 00:00:32.048
Received 5 login tokens. | 2019-07-22 00:00:32.199
Symbol settings MD5 received. Request ID: 1. | 2019-07-22 00:00:32.229
Symbol settings are up-to-date for rithmic.trading. | 2019-07-22 00:00:32.229
Rithmic Trading | Port for executable: 63349 | 2019-07-22 00:00:37.224
Listening socket (1156). Port 63349 | Closed. | 2019-07-22 00:00:37.224
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:00:37.225
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63349. Current folder: C:\SierraChart\Rim | 2019-07-22 00:00:37.246
Rithmic Trading | Bridge process is running. | 2019-07-22 00:00:39.233
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63349 | 2019-07-22 00:00:39.233
DTC Client socket (1) | Creating socket. | 2019-07-22 00:00:39.233
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:00:39.233
Rithmic Trading | Connected to server. | 2019-07-22 00:00:39.234
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:00:39.234
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:00:39.234
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:00:39.236
Rithmic Trading | Sending logon request message. | 2019-07-22 00:00:39.236
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:00:39.237
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:00:39.238
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:00:39.238
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:00:40.993
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:00:41.133
Rithmic Trading | Received logon response. | 2019-07-22 00:00:41.133
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:00:41.133
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:00:41.133
Rithmic Trading | Logon error received from server | 2019-07-22 00:00:41.133
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:00:41.133
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:41.133
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:00:41.165
Rithmic Trading | Disconnected. | 2019-07-22 00:00:41.165
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:41.165
Rithmic Trading | Port for executable: 63361 | 2019-07-22 00:00:43.159
Listening socket (1504). Port 63361 | Closed. | 2019-07-22 00:00:43.159
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:00:43.159
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63361. Current folder: C:\SierraChart\Rim | 2019-07-22 00:00:43.186
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:00:45.188
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63361 | 2019-07-22 00:00:45.188
DTC Client socket (2) | Creating socket. | 2019-07-22 00:00:45.188
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:00:45.188
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:00:47.190 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:00:47.191
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:47.191
DTC Client socket (2) | Closed. | 2019-07-22 00:00:47.191
Rithmic Trading | Disconnected. | 2019-07-22 00:00:47.212
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:47.212
Rithmic Trading | Port for executable: 63363 | 2019-07-22 00:00:49.208
Listening socket (1492). Port 63363 | Closed. | 2019-07-22 00:00:49.208
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:00:49.208
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63363. Current folder: C:\SierraChart\Rim | 2019-07-22 00:00:49.228
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:00:51.219
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63363 | 2019-07-22 00:00:51.219
DTC Client socket (2) | Creating socket. | 2019-07-22 00:00:51.219
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:00:51.219
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:00:53.222 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:00:53.223
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:53.223
DTC Client socket (2) | Closed. | 2019-07-22 00:00:53.223
Rithmic Trading | Disconnected. | 2019-07-22 00:00:53.233
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:53.233
Rithmic Trading | Port for executable: 63366 | 2019-07-22 00:00:55.238
Listening socket (1504). Port 63366 | Closed. | 2019-07-22 00:00:55.238
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:00:55.239
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63366. Current folder: C:\SierraChart\Rim | 2019-07-22 00:00:55.260
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:00:57.250
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63366 | 2019-07-22 00:00:57.250
DTC Client socket (2) | Creating socket. | 2019-07-22 00:00:57.250
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:00:57.250
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:00:59.254 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:00:59.255
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:59.255
DTC Client socket (2) | Closed. | 2019-07-22 00:00:59.255
Rithmic Trading | Disconnected. | 2019-07-22 00:00:59.265
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:00:59.265
Rithmic Trading | Port for executable: 63368 | 2019-07-22 00:01:01.278
Listening socket (1536). Port 63368 | Closed. | 2019-07-22 00:01:01.278
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:01.279
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63368. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:01.303
DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert
durch den Hostcomputer abgebrochen. | 2019-07-22 00:01:02.293 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:01:02.293
DTC Client socket (1) | Closed. | 2019-07-22 00:01:02.293
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:03.298
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63368 | 2019-07-22 00:01:03.298
DTC Client socket (1) | Creating socket. | 2019-07-22 00:01:03.298
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:03.298
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:05.301 *
DTC Client socket (1) | Closed. | 2019-07-22 00:01:05.315
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:05.315
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:05.316
Rithmic Trading | Disconnected. | 2019-07-22 00:01:05.327
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:05.327
Rithmic Trading | Port for executable: 63370 | 2019-07-22 00:01:07.330
Listening socket (1544). Port 63370 | Closed. | 2019-07-22 00:01:07.330
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:07.330
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63370. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:07.352
Rithmic Trading | Bridge process is running. | 2019-07-22 00:01:09.345
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63370 | 2019-07-22 00:01:09.345
DTC Client socket (1) | Creating socket. | 2019-07-22 00:01:09.345
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:09.345
Rithmic Trading | Connected to server. | 2019-07-22 00:01:09.346
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:01:09.346
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:01:09.346
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:01:09.347
Rithmic Trading | Sending logon request message. | 2019-07-22 00:01:09.347
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:01:09.348
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:01:09.351
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-07-22 00:01:09.351
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:01:10.681
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:01:10.810
Rithmic Trading | Received logon response. | 2019-07-22 00:01:10.811
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:01:10.811
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:01:10.811
Rithmic Trading | Logon error received from server | 2019-07-22 00:01:10.811
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:10.811
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:10.811
Rithmic Trading | Disconnected. | 2019-07-22 00:01:10.833
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:10.833
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:01:10.833
Rithmic Trading | Port for executable: 63380 | 2019-07-22 00:01:12.829
Listening socket (1536). Port 63380 | Closed. | 2019-07-22 00:01:12.829
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:12.831
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63380. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:12.852
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:14.843
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63380 | 2019-07-22 00:01:14.843
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:14.843
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:14.843
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:16.845 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:16.845
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:16.845
DTC Client socket (2) | Closed. | 2019-07-22 00:01:16.845
Rithmic Trading | Disconnected. | 2019-07-22 00:01:16.865
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:16.865
Rithmic Trading | Port for executable: 63382 | 2019-07-22 00:01:18.861
Listening socket (1540). Port 63382 | Closed. | 2019-07-22 00:01:18.861
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:18.862
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63382. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:18.881
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:20.874
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63382 | 2019-07-22 00:01:20.874
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:20.874
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:20.875
Created the DTC Protocol server. | 2019-07-22 00:01:22.668
DTC Protocol Server listening on port 11099. | 2019-07-22 00:01:22.670
Created the DTC Protocol historical data server. | 2019-07-22 00:01:22.670
HD Server Manager | Listening on port 11098 | 2019-07-22 00:01:22.672
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:22.876 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:22.877
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:22.877
DTC Client socket (2) | Closed. | 2019-07-22 00:01:22.877
Rithmic Trading | Disconnected. | 2019-07-22 00:01:22.892
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:22.892
Rithmic Trading | Port for executable: 63384 | 2019-07-22 00:01:24.894
Listening socket (764). Port 63384 | Closed. | 2019-07-22 00:01:24.894
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:24.895
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63384. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:24.916
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:26.907
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63384 | 2019-07-22 00:01:26.907
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:26.907
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:26.907
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:28.912 *
DTC Client socket (2) | Closed. | 2019-07-22 00:01:28.913
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:28.913
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:28.913
Rithmic Trading | Disconnected. | 2019-07-22 00:01:28.922
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:28.922
Rithmic Trading | Port for executable: 63386 | 2019-07-22 00:01:30.924
Listening socket (1092). Port 63386 | Closed. | 2019-07-22 00:01:30.924
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:30.925
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63386. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:30.944
durch den Hostcomputer abgebrochen. | 2019-07-22 00:01:32.405 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:01:32.405
DTC Client socket (1) | Closed. | 2019-07-22 00:01:32.405
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:32.940
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63386 | 2019-07-22 00:01:32.940
DTC Client socket (1) | Creating socket. | 2019-07-22 00:01:32.940
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:32.940
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:34.942 *
DTC Client socket (1) | Closed. | 2019-07-22 00:01:34.942
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:34.942
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:34.942
Rithmic Trading | Disconnected. | 2019-07-22 00:01:34.953
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:34.953
Rithmic Trading | Port for executable: 63389 | 2019-07-22 00:01:36.954
Listening socket (1120). Port 63389 | Closed. | 2019-07-22 00:01:36.954
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:36.955
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63389. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:36.976
Rithmic Trading | Bridge process is running. | 2019-07-22 00:01:38.969
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63389 | 2019-07-22 00:01:38.969
DTC Client socket (1) | Creating socket. | 2019-07-22 00:01:38.969
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:38.969
Rithmic Trading | Connected to server. | 2019-07-22 00:01:38.970
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:01:38.970
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:01:38.970
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:01:38.971
Rithmic Trading | Sending logon request message. | 2019-07-22 00:01:38.971
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:01:38.971
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:01:38.974
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:01:38.974
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:01:40.557
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:01:40.691
Rithmic Trading | Received logon response. | 2019-07-22 00:01:40.691
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:01:40.691
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:01:40.691
Rithmic Trading | Logon error received from server | 2019-07-22 00:01:40.691
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:40.691
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:40.691
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:01:40.729
Rithmic Trading | Disconnected. | 2019-07-22 00:01:40.729
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:40.729
Rithmic Trading | Port for executable: 63399 | 2019-07-22 00:01:42.725
Listening socket (1092). Port 63399 | Closed. | 2019-07-22 00:01:42.725
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:42.726
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63399. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:42.750
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:44.749
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63399 | 2019-07-22 00:01:44.749
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:44.749
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:44.749
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:46.751 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:46.751
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:46.751
DTC Client socket (2) | Closed. | 2019-07-22 00:01:46.751
Rithmic Trading | Disconnected. | 2019-07-22 00:01:46.766
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:46.766
Rithmic Trading | Port for executable: 63401 | 2019-07-22 00:01:48.767
Listening socket (1388). Port 63401 | Closed. | 2019-07-22 00:01:48.767
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:48.768
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63401. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:48.788
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:50.781
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63401 | 2019-07-22 00:01:50.781
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:50.781
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:50.782
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:52.783 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:52.783
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:52.783
DTC Client socket (2) | Closed. | 2019-07-22 00:01:52.783
Rithmic Trading | Disconnected. | 2019-07-22 00:01:52.805
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:52.805
Rithmic Trading | Port for executable: 63403 | 2019-07-22 00:01:54.799
Listening socket (1544). Port 63403 | Closed. | 2019-07-22 00:01:54.799
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:01:54.800
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63403. Current folder: C:\SierraChart\Rim | 2019-07-22 00:01:54.820
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:01:56.814
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63403 | 2019-07-22 00:01:56.814
DTC Client socket (2) | Creating socket. | 2019-07-22 00:01:56.814
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:01:56.815
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:01:58.815 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:01:58.815
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:58.815
DTC Client socket (2) | Closed. | 2019-07-22 00:01:58.816
Rithmic Trading | Disconnected. | 2019-07-22 00:01:58.827
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:01:58.827
Rithmic Trading | Port for executable: 63405 | 2019-07-22 00:02:00.830
Listening socket (1544). Port 63405 | Closed. | 2019-07-22 00:02:00.830
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:00.832
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63405. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:00.852
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:02:02.034
DTC Client socket (1) | Closed. | 2019-07-22 00:02:02.034
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:02.843
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63405 | 2019-07-22 00:02:02.843
DTC Client socket (1) | Creating socket. | 2019-07-22 00:02:02.843
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:02.843
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:02:04.845 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:04.845
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:04.845
DTC Client socket (1) | Closed. | 2019-07-22 00:02:04.845
Rithmic Trading | Disconnected. | 2019-07-22 00:02:04.866
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:04.866
Rithmic Trading | Port for executable: 63407 | 2019-07-22 00:02:06.860
Listening socket (1388). Port 63407 | Closed. | 2019-07-22 00:02:06.860
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:06.861
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63407. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:06.884
Rithmic Trading | Bridge process is running. | 2019-07-22 00:02:08.877
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63407 | 2019-07-22 00:02:08.877
DTC Client socket (1) | Creating socket. | 2019-07-22 00:02:08.877
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:08.878
Rithmic Trading | Connected to server. | 2019-07-22 00:02:08.878
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:02:08.878
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:02:08.878
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:02:08.880
Rithmic Trading | Sending logon request message. | 2019-07-22 00:02:08.880
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:02:08.881
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:02:08.883
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:02:08.883
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:02:10.118
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:02:10.249
Rithmic Trading | Received logon response. | 2019-07-22 00:02:10.249
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:02:10.249
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:02:10.249
Rithmic Trading | Logon error received from server | 2019-07-22 00:02:10.249
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:10.249
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:10.249
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:02:10.287
Rithmic Trading | Disconnected. | 2019-07-22 00:02:10.287
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:10.287
Rithmic Trading | Port for executable: 63417 | 2019-07-22 00:02:12.294
Listening socket (1552). Port 63417 | Closed. | 2019-07-22 00:02:12.294
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:12.294
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63417. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:12.314
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:14.326
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63417 | 2019-07-22 00:02:14.326
DTC Client socket (2) | Creating socket. | 2019-07-22 00:02:14.326
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:14.326
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:02:16.330 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:16.330
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:16.330
DTC Client socket (2) | Closed. | 2019-07-22 00:02:16.330
Rithmic Trading | Disconnected. | 2019-07-22 00:02:16.352
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:16.352
Rithmic Trading | Port for executable: 63419 | 2019-07-22 00:02:18.345
Listening socket (1548). Port 63419 | Closed. | 2019-07-22 00:02:18.345
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:18.346
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63419. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:18.368
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:20.358
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63419 | 2019-07-22 00:02:20.358
DTC Client socket (2) | Creating socket. | 2019-07-22 00:02:20.358
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:20.358
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:02:22.361 *
DTC Client socket (2) | Closed. | 2019-07-22 00:02:22.361
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:22.361
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:22.361
Rithmic Trading | Disconnected. | 2019-07-22 00:02:22.381
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:22.381
Rithmic Trading | Port for executable: 63421 | 2019-07-22 00:02:24.379
Listening socket (1536). Port 63421 | Closed. | 2019-07-22 00:02:24.379
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:24.380
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63421. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:24.406
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:26.405
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63421 | 2019-07-22 00:02:26.405
DTC Client socket (2) | Creating socket. | 2019-07-22 00:02:26.406
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:26.406
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:02:28.406 *
DTC Client socket (2) | Closed. | 2019-07-22 00:02:28.406
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:28.406
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:28.406
Rithmic Trading | Disconnected. | 2019-07-22 00:02:28.421
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:28.421
Rithmic Trading | Port for executable: 63423 | 2019-07-22 00:02:30.422
Listening socket (1520). Port 63423 | Closed. | 2019-07-22 00:02:30.423
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:30.423
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63423. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:30.445
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:02:31.942
DTC Client socket (1) | Closed. | 2019-07-22 00:02:31.942
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:32.438
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63423 | 2019-07-22 00:02:32.438
DTC Client socket (1) | Creating socket. | 2019-07-22 00:02:32.438
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:32.439
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:02:34.442 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:34.442
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:34.443
DTC Client socket (1) | Closed. | 2019-07-22 00:02:34.443
Rithmic Trading | Disconnected. | 2019-07-22 00:02:34.453
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:34.453
Rithmic Trading | Port for executable: 63426 | 2019-07-22 00:02:36.458
Listening socket (1100). Port 63426 | Closed. | 2019-07-22 00:02:36.458
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:36.459
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63426. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:36.484
File >> Disconnect selected. | 2019-07-22 00:02:37.790
Rithmic Trading | Disconnected. | 2019-07-22 00:02:37.790
Rithmic Trading | Port for executable: 63427 | 2019-07-22 00:02:50.604
Listening socket (1504). Port 63427 | Closed. | 2019-07-22 00:02:50.604
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:50.605
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63427. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:50.628
Rithmic Trading | Bridge process is running. | 2019-07-22 00:02:52.627
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63427 | 2019-07-22 00:02:52.627
DTC Client socket (1) | Creating socket. | 2019-07-22 00:02:52.627
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:52.627
Rithmic Trading | Connected to server. | 2019-07-22 00:02:52.628
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:02:52.628
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:02:52.628
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:02:52.629
Rithmic Trading | Sending logon request message. | 2019-07-22 00:02:52.629
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:02:52.630
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:02:52.632
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:02:52.632
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:02:53.860
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:02:53.990
Rithmic Trading | Received logon response. | 2019-07-22 00:02:53.990
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:02:53.990
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:02:53.990
Rithmic Trading | Logon error received from server | 2019-07-22 00:02:53.990
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:02:53.990
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:53.990
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:02:54.026
Rithmic Trading | Disconnected. | 2019-07-22 00:02:54.026
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:02:54.026
Rithmic Trading | Port for executable: 63437 | 2019-07-22 00:02:56.018
Listening socket (1536). Port 63437 | Closed. | 2019-07-22 00:02:56.018
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:02:56.018
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63437. Current folder: C:\SierraChart\Rim | 2019-07-22 00:02:56.041
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:02:58.031
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63437 | 2019-07-22 00:02:58.031
DTC Client socket (2) | Creating socket. | 2019-07-22 00:02:58.031
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:02:58.031
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:00.034 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:00.034
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:00.034
DTC Client socket (2) | Closed. | 2019-07-22 00:03:00.034
Rithmic Trading | Disconnected. | 2019-07-22 00:03:00.053
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:00.053
Rithmic Trading | Port for executable: 63439 | 2019-07-22 00:03:02.049
Listening socket (1536). Port 63439 | Closed. | 2019-07-22 00:03:02.049
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:02.049
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63439. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:02.068
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:04.064
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63439 | 2019-07-22 00:03:04.064
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:04.064
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:04.064
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:06.069 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:06.069
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:06.069
DTC Client socket (2) | Closed. | 2019-07-22 00:03:06.069
Rithmic Trading | Disconnected. | 2019-07-22 00:03:06.079
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:06.079
Rithmic Trading | Port for executable: 63441 | 2019-07-22 00:03:08.083
Listening socket (1552). Port 63441 | Closed. | 2019-07-22 00:03:08.083
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:08.083
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63441. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:08.107
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:10.095
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63441 | 2019-07-22 00:03:10.095
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:10.096
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:10.096
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:12.098 *
DTC Client socket (2) | Closed. | 2019-07-22 00:03:12.099
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:12.099
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:12.099
Rithmic Trading | Disconnected. | 2019-07-22 00:03:12.108
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:12.108
Rithmic Trading | Port for executable: 63443 | 2019-07-22 00:03:14.110
Listening socket (1564). Port 63443 | Closed. | 2019-07-22 00:03:14.110
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:14.111
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63443. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:14.134
durch den Hostcomputer abgebrochen. | 2019-07-22 00:03:15.686 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:03:15.686
DTC Client socket (1) | Closed. | 2019-07-22 00:03:15.686
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:16.127
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63443 | 2019-07-22 00:03:16.127
DTC Client socket (1) | Creating socket. | 2019-07-22 00:03:16.127
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:16.127
Disabled DTC protocol server. Disconnecting clients. | 2019-07-22 00:03:17.545
HD Server Manager | Starting exit sequence. | 2019-07-22 00:03:17.545
HD Server Manager | Closing listening socket for port 11098 | 2019-07-22 00:03:17.545
Listening socket (1528). Port 11098 | Closed. | 2019-07-22 00:03:17.545
HD Server Manager | Signaling the client threads for the historical data server to end. | 2019-07-22 00:03:17.546
HD Server Manager | All client threads have ended. | 2019-07-22 00:03:17.546
Deleted the DTC Protocol historical data server. | 2019-07-22 00:03:17.546
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:18.130 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:18.130
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:18.130
DTC Client socket (1) | Closed. | 2019-07-22 00:03:18.130
Rithmic Trading | Disconnected. | 2019-07-22 00:03:18.140
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:18.140
Rithmic Trading | Port for executable: 63446 | 2019-07-22 00:03:20.142
Listening socket (1548). Port 63446 | Closed. | 2019-07-22 00:03:20.142
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:20.142
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63446. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:20.163
Rithmic Trading | Bridge process is running. | 2019-07-22 00:03:22.156
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63446 | 2019-07-22 00:03:22.156
DTC Client socket (1) | Creating socket. | 2019-07-22 00:03:22.157
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:22.157
Rithmic Trading | Connected to server. | 2019-07-22 00:03:22.157
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:03:22.157
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:03:22.157
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:03:22.159
Rithmic Trading | Sending logon request message. | 2019-07-22 00:03:22.159
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:03:22.160
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:03:22.162
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:03:22.162
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:03:23.374
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:03:23.505
Rithmic Trading | Received logon response. | 2019-07-22 00:03:23.505
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:03:23.505
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:03:23.505
Rithmic Trading | Logon error received from server | 2019-07-22 00:03:23.505
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:23.505
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:23.505
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:03:23.541
Rithmic Trading | Disconnected. | 2019-07-22 00:03:23.541
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:23.541
Rithmic Trading | Port for executable: 63456 | 2019-07-22 00:03:25.536
Listening socket (1528). Port 63456 | Closed. | 2019-07-22 00:03:25.536
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:25.537
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63456. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:25.559
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:27.548
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63456 | 2019-07-22 00:03:27.548
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:27.548
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:27.548
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:29.552 *
DTC Client socket (2) | Closed. | 2019-07-22 00:03:29.552
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:29.552
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:29.552
Rithmic Trading | Disconnected. | 2019-07-22 00:03:29.562
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:29.562
Rithmic Trading | Port for executable: 63459 | 2019-07-22 00:03:31.564
Listening socket (1524). Port 63459 | Closed. | 2019-07-22 00:03:31.564
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:31.565
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63459. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:31.588
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:33.577
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63459 | 2019-07-22 00:03:33.577
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:33.577
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:33.577
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:35.580 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:35.580
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:35.580
DTC Client socket (2) | Closed. | 2019-07-22 00:03:35.580
Rithmic Trading | Disconnected. | 2019-07-22 00:03:35.601
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:35.601
Rithmic Trading | Port for executable: 63461 | 2019-07-22 00:03:37.597
Listening socket (1492). Port 63461 | Closed. | 2019-07-22 00:03:37.597
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:37.598
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63461. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:37.622
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:39.610
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63461 | 2019-07-22 00:03:39.610
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:39.611
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:39.611
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:41.614 *
DTC Client socket (2) | Closed. | 2019-07-22 00:03:41.614
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:41.614
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:41.614
Rithmic Trading | Disconnected. | 2019-07-22 00:03:41.624
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:41.625
Rithmic Trading | Port for executable: 63463 | 2019-07-22 00:03:43.629
Listening socket (1072). Port 63463 | Closed. | 2019-07-22 00:03:43.629
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:43.630
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63463. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:43.651
durch den Hostcomputer abgebrochen. | 2019-07-22 00:03:45.218 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:03:45.218
DTC Client socket (1) | Closed. | 2019-07-22 00:03:45.218
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:45.641
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63463 | 2019-07-22 00:03:45.641
DTC Client socket (1) | Creating socket. | 2019-07-22 00:03:45.641
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:45.641
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:47.643 *
DTC Client socket (1) | Closed. | 2019-07-22 00:03:47.643
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:47.643
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:47.643
Rithmic Trading | Disconnected. | 2019-07-22 00:03:47.665
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:47.665
Rithmic Trading | Port for executable: 63465 | 2019-07-22 00:03:49.659
Listening socket (1072). Port 63465 | Closed. | 2019-07-22 00:03:49.659
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:49.660
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63465. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:49.683
Rithmic Trading | Bridge process is running. | 2019-07-22 00:03:51.673
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63465 | 2019-07-22 00:03:51.673
DTC Client socket (1) | Creating socket. | 2019-07-22 00:03:51.673
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:51.673
Rithmic Trading | Connected to server. | 2019-07-22 00:03:51.675
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:03:51.675
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:03:51.675
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:03:51.676
Rithmic Trading | Sending logon request message. | 2019-07-22 00:03:51.676
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:03:51.677
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:03:51.679
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:03:51.679
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:03:52.914
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:03:53.043
Rithmic Trading | Received logon response. | 2019-07-22 00:03:53.043
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:03:53.043
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:03:53.043
Rithmic Trading | Logon error received from server | 2019-07-22 00:03:53.043
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:53.043
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:53.043
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:03:53.078
Rithmic Trading | Disconnected. | 2019-07-22 00:03:53.078
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:53.078
Rithmic Trading | Port for executable: 63475 | 2019-07-22 00:03:55.080
Listening socket (1576). Port 63475 | Closed. | 2019-07-22 00:03:55.080
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:03:55.081
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63475. Current folder: C:\SierraChart\Rim | 2019-07-22 00:03:55.105
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:03:57.093
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63475 | 2019-07-22 00:03:57.093
DTC Client socket (2) | Creating socket. | 2019-07-22 00:03:57.093
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:03:57.093
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:03:59.095 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:03:59.095
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:59.095
DTC Client socket (2) | Closed. | 2019-07-22 00:03:59.095
Rithmic Trading | Disconnected. | 2019-07-22 00:03:59.115
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:03:59.115
Rithmic Trading | Port for executable: 63477 | 2019-07-22 00:04:01.124
Listening socket (1576). Port 63477 | Closed. | 2019-07-22 00:04:01.124
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:04:01.125
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63477. Current folder: C:\SierraChart\Rim | 2019-07-22 00:04:01.149
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:04:03.140
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63477 | 2019-07-22 00:04:03.140
DTC Client socket (2) | Creating socket. | 2019-07-22 00:04:03.140
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:04:03.140
File >> Disconnect selected. | 2019-07-22 00:04:04.242
Rithmic Trading | Disconnected. | 2019-07-22 00:04:04.242
DTC Client socket (2) | Closed. | 2019-07-22 00:04:04.242
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:04:14.740
DTC Client socket (1) | Closed. | 2019-07-22 00:04:14.740
Rithmic Trading | Port for executable: 63518 | 2019-07-22 00:07:05.255
Listening socket (1072). Port 63518 | Closed. | 2019-07-22 00:07:05.255
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:07:05.255
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63518. Current folder: C:\SierraChart\Rim | 2019-07-22 00:07:05.281
Rithmic Trading | Bridge process is running. | 2019-07-22 00:07:07.284
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63518 | 2019-07-22 00:07:07.284
DTC Client socket (1) | Creating socket. | 2019-07-22 00:07:07.284
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:07:07.284
Rithmic Trading | Connected to server. | 2019-07-22 00:07:07.285
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:07:07.285
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:07:07.285
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:07:07.286
Rithmic Trading | Sending logon request message. | 2019-07-22 00:07:07.286
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:07:07.288
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:07:07.289
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:07:07.289
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:07:08.534
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:07:08.670
Rithmic Trading | Received logon response. | 2019-07-22 00:07:08.670
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:07:08.670
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:07:08.670
Rithmic Trading | Logon error received from server | 2019-07-22 00:07:08.670
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:07:08.670
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:08.670
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:07:08.708
Rithmic Trading | Disconnected. | 2019-07-22 00:07:08.708
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:08.708
Rithmic Trading | Port for executable: 63528 | 2019-07-22 00:07:10.707
Listening socket (1564). Port 63528 | Closed. | 2019-07-22 00:07:10.707
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:07:10.708
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63528. Current folder: C:\SierraChart\Rim | 2019-07-22 00:07:10.727
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:07:12.724
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63528 | 2019-07-22 00:07:12.725
DTC Client socket (2) | Creating socket. | 2019-07-22 00:07:12.725
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:07:12.725
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:07:14.727 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:07:14.727
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:14.727
DTC Client socket (2) | Closed. | 2019-07-22 00:07:14.727
Rithmic Trading | Disconnected. | 2019-07-22 00:07:14.737
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:14.737
Rithmic Trading | Port for executable: 63531 | 2019-07-22 00:07:16.743
Listening socket (1576). Port 63531 | Closed. | 2019-07-22 00:07:16.743
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:07:16.744
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63531. Current folder: C:\SierraChart\Rim | 2019-07-22 00:07:16.763
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:07:18.752
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63531 | 2019-07-22 00:07:18.752
DTC Client socket (2) | Creating socket. | 2019-07-22 00:07:18.752
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:07:18.752
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:07:20.755 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:07:20.756
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:20.756
DTC Client socket (2) | Closed. | 2019-07-22 00:07:20.756
Rithmic Trading | Disconnected. | 2019-07-22 00:07:20.765
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:07:20.765
File >> Disconnect selected. | 2019-07-22 00:07:20.958
Rithmic Trading | Disconnected. | 2019-07-22 00:07:20.958
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:07:30.331
DTC Client socket (1) | Closed. | 2019-07-22 00:07:30.331
Rithmic Trading | Port for executable: 63545 | 2019-07-22 00:09:55.260
Listening socket (1564). Port 63545 | Closed. | 2019-07-22 00:09:55.260
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:09:55.261
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63545. Current folder: C:\SierraChart\Rim | 2019-07-22 00:09:55.280
Rithmic Trading | Bridge process is running. | 2019-07-22 00:09:57.292
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63545 | 2019-07-22 00:09:57.292
DTC Client socket (1) | Creating socket. | 2019-07-22 00:09:57.292
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:09:57.293
Rithmic Trading | Connected to server. | 2019-07-22 00:09:57.294
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:09:57.294
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:09:57.294
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:09:57.295
Rithmic Trading | Sending logon request message. | 2019-07-22 00:09:57.295
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:09:57.296
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:09:57.298
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:09:57.298
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:09:58.520
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:09:58.657
Rithmic Trading | Received logon response. | 2019-07-22 00:09:58.657
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:09:58.657
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:09:58.657
Rithmic Trading | Logon error received from server | 2019-07-22 00:09:58.657
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:09:58.657
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:09:58.657
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:09:58.693
Rithmic Trading | Disconnected. | 2019-07-22 00:09:58.693
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:09:58.693
Rithmic Trading | Port for executable: 63555 | 2019-07-22 00:10:00.689
Listening socket (1532). Port 63555 | Closed. | 2019-07-22 00:10:00.689
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:00.690
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63555. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:00.709
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:02.703
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63555 | 2019-07-22 00:10:02.703
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:02.703
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:02.704
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:04.706 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:04.706
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:04.706
DTC Client socket (2) | Closed. | 2019-07-22 00:10:04.706
Rithmic Trading | Disconnected. | 2019-07-22 00:10:04.726
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:04.726
Rithmic Trading | Port for executable: 63557 | 2019-07-22 00:10:06.726
Listening socket (1492). Port 63557 | Closed. | 2019-07-22 00:10:06.726
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:06.726
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63557. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:06.745
Service is currently connecting. | 2019-07-22 00:10:06.930 *
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:08.741
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63557 | 2019-07-22 00:10:08.741
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:08.741
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:08.741
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:10.745 *
DTC Client socket (2) | Closed. | 2019-07-22 00:10:10.745
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:10.745
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:10.745
Rithmic Trading | Disconnected. | 2019-07-22 00:10:10.751
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:10.751
Rithmic Trading | Port for executable: 63559 | 2019-07-22 00:10:12.754
Listening socket (1092). Port 63559 | Closed. | 2019-07-22 00:10:12.754
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:12.755
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63559. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:12.773
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:14.766
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63559 | 2019-07-22 00:10:14.766
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:14.766
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:14.766
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:16.769 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:16.769
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:16.769
DTC Client socket (2) | Closed. | 2019-07-22 00:10:16.769
Rithmic Trading | Disconnected. | 2019-07-22 00:10:16.780
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:16.780
Rithmic Trading | Port for executable: 63561 | 2019-07-22 00:10:18.793
Listening socket (1524). Port 63561 | Closed. | 2019-07-22 00:10:18.793
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:18.794
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63561. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:18.812
DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert
durch den Hostcomputer abgebrochen. | 2019-07-22 00:10:20.335 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:10:20.335
DTC Client socket (1) | Closed. | 2019-07-22 00:10:20.335
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:20.812
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63561 | 2019-07-22 00:10:20.812
DTC Client socket (1) | Creating socket. | 2019-07-22 00:10:20.812
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:20.812
DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:22.814 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:22.814
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:22.814
DTC Client socket (1) | Closed. | 2019-07-22 00:10:22.814
Rithmic Trading | Disconnected. | 2019-07-22 00:10:22.827
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:22.827
Rithmic Trading | Port for executable: 63563 | 2019-07-22 00:10:24.830
Listening socket (1560). Port 63563 | Closed. | 2019-07-22 00:10:24.830
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:24.830
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63563. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:24.849
Rithmic Trading | Bridge process is running. | 2019-07-22 00:10:26.844
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63563 | 2019-07-22 00:10:26.844
DTC Client socket (1) | Creating socket. | 2019-07-22 00:10:26.844
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:26.844
Rithmic Trading | Connected to server. | 2019-07-22 00:10:26.845
Rithmic Trading | Starting socket receive thread. | 2019-07-22 00:10:26.845
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-22 00:10:26.845
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-22 00:10:26.847
Rithmic Trading | Sending logon request message. | 2019-07-22 00:10:26.847
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-22 00:10:26.848
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-07-22 00:10:26.849
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-22 00:10:26.849
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-22 00:10:28.042
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-07-22 00:10:28.173
Rithmic Trading | Received logon response. | 2019-07-22 00:10:28.173
Rithmic Trading | Server Name: DTC Bridge. | 2019-07-22 00:10:28.173
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-22 00:10:28.173
Rithmic Trading | Logon error received from server | 2019-07-22 00:10:28.173
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:28.173
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:28.173
Rithmic Trading | Disconnected. | 2019-07-22 00:10:28.202
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:28.202
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-22 00:10:28.202
Rithmic Trading | Port for executable: 63574 | 2019-07-22 00:10:30.208
Listening socket (1504). Port 63574 | Closed. | 2019-07-22 00:10:30.208
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:30.208
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63574. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:30.228
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:32.224
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63574 | 2019-07-22 00:10:32.224
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:32.224
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:32.224
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:34.228 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:34.229
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:34.229
DTC Client socket (2) | Closed. | 2019-07-22 00:10:34.229
Rithmic Trading | Disconnected. | 2019-07-22 00:10:34.239
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:34.239
Rithmic Trading | Port for executable: 63577 | 2019-07-22 00:10:36.242
Listening socket (1504). Port 63577 | Closed. | 2019-07-22 00:10:36.242
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:36.242
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63577. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:36.263
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:38.251
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63577 | 2019-07-22 00:10:38.251
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:38.251
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:38.251
DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-07-22 00:10:40.254 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-07-22 00:10:40.255
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:40.255
DTC Client socket (2) | Closed. | 2019-07-22 00:10:40.255
Rithmic Trading | Disconnected. | 2019-07-22 00:10:40.265
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-22 00:10:40.265
Rithmic Trading | Port for executable: 63579 | 2019-07-22 00:10:42.268
Listening socket (1524). Port 63579 | Closed. | 2019-07-22 00:10:42.268
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-07-22 00:10:42.269
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63579. Current folder: C:\SierraChart\Rim | 2019-07-22 00:10:42.287
Rithmic Trading | Bridge process is not running! | 2019-07-22 00:10:44.281
Rithmic Trading | Connecting to the server 127.0.0.1. Port 63579 | 2019-07-22 00:10:44.281
DTC Client socket (2) | Creating socket. | 2019-07-22 00:10:44.281
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-07-22 00:10:44.282
File >> Disconnect selected. | 2019-07-22 00:10:45.442
Rithmic Trading | Disconnected. | 2019-07-22 00:10:45.442
DTC Client socket (2) | Closed. | 2019-07-22 00:10:45.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-07-22 00:10:49.903
DTC Client socket (1) | Closed. | 2019-07-22 00:10:49.903
[2019-07-22 09:10:41]
This is the relevant message:
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
