Date/Time: Fri, 07 Feb 2025 15:18:44 +0000
[Programming Help] - Apply study when another study is triggered
View Count: 862
[2019-07-21 02:48:04]
User161560 - Posts: 19
Hi - I want to plot the VPOC of a single bar and color that bar orange when the volume on that bar exceeds a specified threshold.
I used the formula =V>=3000 on the Color Bar Based On Alert Condition Study which colors the bar orange when volume for that bar is >= 3000, which works great. And I have the Volume By Price Study set to highlight only the VPOC of every bar, which works great highlighting the VPOC of every bar. I added the formula =V>=3000 to the Volume By Price Alert Condition box but it doesn't do anything. I'm pretty sure I'm missing something basic but got stuck. Any ideas how I might make this work to highlight the VPOC and color the bar orange on every bar with volume >= 3000?
Thanks!
Simon
[2019-07-21 04:27:06]
mpro - Posts: 44
You can get the VPOC Value and Volume with Numbers Bars Calculated Values. The Color Bar Based On Alert Condition should be based on the value.
Date Time Of Last Edit: 2019-07-21 04:28:12
[2019-07-21 07:50:06]
mpro - Posts: 44
See attached files.
imageHighlight_VPOC_and_Candle_3000.png / V - Attached On 2019-07-21 07:49:08 UTC - Size: 9.39 KB - 339 views
attachmentHighlight_VPOC_and_Candle_3000+.StdyCollct - Attached On 2019-07-21 07:49:26 UTC - Size: 28.03 KB - 550 views
[2019-07-30 05:17:24]
To access the volume point of control value in a Subgraph from the Volume by Price study refer to:
Volume By Price Study: Programmatically Accessing Volume at Price Data
Also, using ACSIL you can access the point of control of a chart bar with this function:
sc.GetPointOfControlPriceVolumeForBar()
