Date/Time: Thu, 02 May 2024 19:41:18 +0000
Recalculate X&Y after resizing window
View Count: 852
[2019-07-20 10:19:30] |
Mack - Posts: 83 |
Something that is a little bit annoying is that you have to rescale charts after you maximize/restore a chart window. I use the "Set X & Y Constant Relationship" together with "Interactive Scale Range" and "Scale Range: Constant Range". I have a made a quick screen-cap to illustrate what I mean. Here you can see that you have to rescale the chart, every time you change the window size. https://www.youtube.com/watch?v=8WLkXwPct64&feature=youtu.be I think this could technically be solved, if the "X&Y" ratio would adjust automatically if you adjust the chart window size. (from 1/3 screen to say maximize). |
[2019-07-24 05:05:00] |
We will look into this.
[2019-07-26 17:58:53] |
We are not understanding this request and it is not understandable from the video as to what you are trying to explain. We need a precise written explanation as to what you mean about this: you have to rescale charts after you maximize/restore a chart window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 17:59:57
[2019-09-16 13:25:15] |
Mack - Posts: 83 |
My problem has to do with going from "Window Tile Vertically" mode, where I have 3 charts both taking up 33.3% of the screen to going to one chart that takes 100% of the screen. In the process, I lose my "perfect" X&Y ratio! This is my procedure starting with 3 charts, each taking up 33.3% of the screen, from Window Tile Vertically mode: - I maximize one screen, 100% - I press the up arrow - PROBLEM: the X&Y ratio is messed up, the Y factor is actually to small, compressing the view - I right click on the scale, unclick, "Set X&Y Constant Relationship" - I make ratio similar to what is was before, then set X%Y Constant again - Then I can zoom in. I think we can fix this, by automatically adjusting the X&Y relationship when you maximize one screen. Date Time Of Last Edit: 2019-09-16 13:27:56
[2019-09-16 13:26:44] |
Mack - Posts: 83 |
You can see the problem in action, at 00:21 in my video. Here is a link: https://www.youtube.com/watch?v=8WLkXwPct64&feature=youtu.be&t=21s |
