Date/Time: Sat, 01 Feb 2025 15:57:07 +0000
SC became so slow
View Count: 614
[2019-07-20 03:13:50] |
User968625 - Posts: 260 |
Hello, SC has been working great and suddenly it just slowed down dramatically. it is freezing. I am not sure what happened. any diagnoses I need to run? Thank you |
[2019-07-20 05:20:48] |
You just need to refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Also try restarting your computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-20 05:21:08
