Date/Time: Mon, 03 Mar 2025 20:32:18 +0000
Setting a CME e-mini demo account
View Count: 1667
[2019-07-20 00:51:42] |
lucascastro - Posts: 15 |
Hello, I'm getting confused about setting a demo account with sierra charts. Could you guys give some help to set a demo account? Especially if I need to pay for certain data necessary even for the demo account. I tried t understand before proceeding and adding money to the account but Im afraid of expending more than needed to open a demo account. Right now I have a trial activated. What else do I neeed? thanks |
[2019-07-20 01:00:49] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above *completely* before you ask further questions about real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-29 23:40:51] |
OK. I think I prefer to set a simulated futures trade account first with e-mini (ES) with about 10.000us fund. I have already enabled Denali data and level 5 package. Is it right? I'm just not sure what to acquire for a SIm account. The problem is that with Denali I need brokers that I don't have, but I just figured that out after activating it. It is a bit confusing and out of order for how someone should proceed. |
[2019-07-30 17:58:36] |
We apologize for the delay here. I have already enabled Denali data and level 5 package.
Yes this is correct. But the problem is you have activated two different data feeds. You should be using the Denali Exchange Data Feed if you just require CME data. Who is your futures broker? You need that regardless of what particular data feed you are using. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
