Date/Time: Sat, 04 Jul 2026 13:22:23 +0000
AddLineUntilFutureIntersectionEx
View Count: 738
| [2019-07-19 20:29:41] |
| User907968 - Posts: 873 |
Hi, Is there a limit on how far back I can go with 'sc.AddLineUntilFutureIntersectionEx'? I am noticing that if I start adding intersection lines at index between 1500-2000 back from current, then they do not populate as expected. Is this expected behaviour, or do I need to dig into my code to discover why this is happening? Thanks. |
| [2019-07-19 21:39:45] |
No there is no limit. That is not expected. There must be another explanation. Maybe they are out of the current vertical range.
| [2019-07-20 18:53:19] |
Thanks for confirming that the behaviour not as expected. An error at my end, now working as I'd hoped it would. Sorry to waste your time. |
