Date/Time: Sat, 01 Feb 2025 14:55:17 +0000
Disable
View Count: 842
[2019-07-19 19:27:31] |
User731023 - Posts: 138 |
I am in version 1940. When you hover over "Region Dividing Lines" it shows them now. Thanks for that. Is there a way to disable if you want to? Thanks |
[2019-07-19 21:41:07] |
Yes you just need to select something else other than Tools >> Adjust Regions.
[2019-07-21 16:06:05] |
I think I need to clarify. Please see attachments. It older versions it did not show them when mouse when over the area it would be if you checked it. The reason I want to disable this NEW feature is because sometimes if you pass over it and go to another chart it stays ON and you have to go back to that chart for it to go off. |
[2019-07-22 16:17:20] |
This is because you have Tools >> Adjust Regions selected. Select Tools >> Pointer instead.
[2019-07-22 18:34:13] |
Rino - Posts: 124 |
Forgive me for saying this then there is something wrong with version 1940. I absolutely do not or never did have Adjust Regions checked. |
[2019-07-23 04:19:45] |
You have the option enabled which keeps the Adjust Regions tool active with other tools. Refer to: Chart Drawing Tools: Adjust Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
