Date/Time: Sat, 01 Feb 2025 16:00:30 +0000
Footprint - Time Issue
View Count: 630
[2019-07-19 18:00:31] |
User103219 - Posts: 8 |
Please see the attached images which are notated with the time issue. Specifically at 8AM it jumps to 830 to 8 to 830. Then again at 10 to 1030 to 10 to 1030. Thank you in advance. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30157 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30158 |
[2019-07-19 23:16:21] |
There was a problem with the timestamps from the data feed you are using or on your computer. Re-download that data from just before the repeating times: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-19 23:16:40
