Date/Time: Sat, 01 Feb 2025 14:58:13 +0000
Sierra Keeps Crashing and Closing randomly
View Count: 857
[2019-07-19 16:13:09]
User274676 - Posts: 38
Please advise I am using version 1952.
[2019-07-19 16:28:21]
Make sure you are not using the OpenGL option:
Global Settings >> Graphics Settings >> Other >> Use OpenGL for Chart Graphics.
Restart Sierra Chart after disabling that option.
Also run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
The issue could be caused by custom studies:
Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface
Let us know if you still have a problem.
Date Time Of Last Edit: 2019-07-19 16:28:31
[2019-07-22 16:26:15]
Sierra Chart - Max - Posts: 5780
From User:
OpenGL option was not enabled.
I have only ran SC in Safe Mode. Since, then SC has been fine. Has not crashed once.
Could it be my custom indicators?
Sierra Chart Support
[2019-07-22 17:05:20]
Yes it is caused by your custom studies. Refer to help topic 17 here in regards to this:
