Date/Time: Sat, 01 Feb 2025 15:41:19 +0000
Trade Management Study
View Count: 1011
[2019-07-19 11:21:32]
User94606 - Posts: 327
I have a 1 min and 5 second chart in the chartbook for the same symbol (e.g., NQ). The Trade Management Study is only on the 1 min chart (and not in the 5 second chart) and I initiate trades using the 5 second chart thru the "Trade Window to Chart", when the trade is opened/executed, is the Trade Management Study used since this trade was from the 5 second chart?
[2019-07-20 07:39:43]
There should not be any problem with this. But make sure that chart with the Trade Management Study has this option enabled:
Trade Menu: Chart Trade Mode On (Trade menu)
We would have to verify this is necessary, but it is still good practice to have it on anyway.
[2019-07-20 13:23:29]
The Chart Trade Mode On is enabled on the chart that has the Trade Management study. Can you please confirm, if I opened the trade from a different chart that has no Trade Management study and the Trade Management study is enabled on the 1 min chart, the Trade Management study should be active on the 1 minute chart - correct?
Also, is there any precedence on what takes place first if you have a trade management study and also use attached orders (10 tick stop)?
[2019-07-20 21:09:25]
Yes this is correct. We did verify that.
They are both functional at the same time. One does not have precedence over the other.
