Date/Time: Sat, 01 Feb 2025 12:42:55 +0000
Crosshair Anchor
View Count: 956
[2019-07-18 18:57:13] |
gmorgan111 - Posts: 121 |
I have been trying to change the color of the crosshair anchor. I have tried thru the Graphic Settings Global Settings Tool Settings and the color of the anchor remains the same color of dark gray. The arrow pointer is white but the crosshair anchor color is dark gray and I am not able to change it Can you tell me how to change the color please Thanks |
[2019-07-18 21:07:34] |
User138602 - Posts: 169 |
Its a windows item. Only way to make it more visible is to change color of the windows mouse pointer to black. That way, the pointer will get a white outline and this works well with the crosshair anchor...if this is ment to be the little cross you switch to if enabling chart value/crosshair. |
