Date/Time: Sat, 01 Feb 2025 13:01:02 +0000
Can't apply session settings to the CBOT treasuries.
View Count: 646
[2019-07-18 03:56:23]
IconBob - Posts: 61
I have custom session times: 8:20 to 16:59:59 and 18:00 to 8:19:59 that show in the symbol setting but when I apply the times all that is displayed is 0:0 to 23:59:59.
I'm using SC order routing and Rithmic for data feeds and it happens with both.
Version 1952 prerelease.
Also in spreadsheet can't change treasuries format from 1/32 despite what symbol settings are.
Date Time Of Last Edit: 2019-07-18 22:27:06
[2019-07-19 05:03:46]
The instructions for this is here:
Global Symbol Settings: Applying Global Symbol Settings to Existing Intraday Chart
Can you post a screenshot of what you are seeing in the Spreadsheet related to this:
[2019-07-19 12:30:38]
IconBob - Posts: 61
I missed the use custom settings in the upper corner of symbol settings. Applied both suggestions fixed spreadsheet also. I'm good to go.
