Date/Time: Sun, 24 Nov 2024 20:59:07 +0000
weekly
View Count: 1440
[2013-12-03 20:02:16]
User022189 - Posts: 35
how do I change a chart to weekly?
[2013-12-03 21:07:48]
The easiest way is to go to Chart >>Bar Period >> Weekly.
[2013-12-03 21:16:54]
thanks----do u provide your own data yet?
[2013-12-03 21:20:08]
If you are referring to CME futures data, then the answer is yes. Refer to this page:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
The historical Daily charts you are using now, do come from our own data feed.
[2013-12-04 00:37:14]
I understand since I am connected with AMP futures and TTnet, that I can't use your data, correct?
[2013-12-04 00:46:18]
how do I import a zip file into SC?
[2013-12-04 01:31:44]
A zip file containing what?
[2013-12-04 01:32:34]
You can use the Sierra Chart real-time and historical futures data feed With any of the supported Trading services. The only requirement is that you have a direct paid account:
http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html
[2013-12-04 20:00:39]
on the simple moving average, is the length in days?
[2013-12-04 20:13:30]
This depends upon the timeframe of the chart bars.
[2013-12-04 20:35:32]
if the chart bars are 233t, then what?
[2013-12-04 20:57:36]
Refer to help topic 28 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html
[2013-12-05 17:10:40]
what am I supposed to do with that number?
