Date/Time: Thu, 06 Mar 2025 06:02:58 +0000
BOLLINGER BAND SQUEEZE
View Count: 1274
[2019-07-17 19:46:03] |
BLAKE R - Posts: 23 |
HELLO, IS THERE A WAY TO CHANGE THE DEFAULT VALUE OF THE SQUEEZE INDICATOR [ SG2 ] TO A DIFFERENT VALUE OTHER THAN 0. IE 1,2, -1 OR -2. THANK YOU |
[2019-07-19 16:36:30] |
This is something that you are able to do on your side. The source code for the Bollinger Squeeze studies is available in the ACS_Source folder within your main Sierra Chart installation folder. Therefore, you can make the change for yourself and place the dots where ever works best for you. Refer to the following for how to create the DLL for the study: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-19 16:36:52
