Date/Time: Sat, 01 Feb 2025 12:45:47 +0000
Issues with new Denali Exchange Data Feed
View Count: 1670
[2019-07-17 16:45:25]
User268716 - Posts: 3
Good Morning,
I just switched from Rithmic to the new Denali Exchange Data Feed and I'm having trouble getting data to populate. My Sierra Chart account number is __ and my broker is AMP. I've been trying to access the SC Data - All Services for my data but no updated data populates on my chart or DOM. Please let me know what I need to do to resolve this issue.
Thank you,
Cody
Date Time Of Last Edit: 2019-07-17 16:51:25
[2019-07-17 16:59:41]
You still need to connect Sierra Chart to Rithmic once a month. Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount
And update the symbols with this command:
Edit Menu: Edit >> Translate Symbols To Current Service (Edit >> Translate Symbols To Current Service)
[2019-07-19 16:00:16]
Thank you for your reply. I'm still a little confused though. I just switched over from Rithmic to Denali a few days ago in hopes of no longer using Rithmic going forward. I've logged onto Rithmic during the month but when using SC Data - All Services (Denali) I'm still not receiving any data, even after running the command Edit>>Translate Symbols To Current Service. Am I doing something wrong? Should I be using SC Data - All Services for Denali?
[2019-07-19 16:20:46]
But you still need to use Rithmic, CQG or TT for sending orders. And to be compliant with CME exchange rules for market data. There's no way to avoid that.
Do you still have an account on Rithmic?
In regards to not receiving market data at this time, follow the instructions below and we will see what the problem is:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2019-07-19 17:37:48]
Software version: 1951 64-bit | 2019-07-19 10:35:17.706
Enabled for: Advanced Features 2. | 2019-07-19 10:35:17.706
Enabled for: Sierra Chart Historical Data Service. | 2019-07-19 10:35:17.706
Enabled for exchange2: CME (Trading Account Required) | 2019-07-19 10:35:17.706
Enabled for exchange2: CBOT (Trading Account Required) | 2019-07-19 10:35:17.706
Enabled for exchange2: COMEX (Trading Account Required) | 2019-07-19 10:35:17.706
Enabled for exchange2: NYMEX (Trading Account Required) | 2019-07-19 10:35:17.706
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-07-19 10:35:17.706
Current selected Data/Trading service: Rithmic Trading | 2019-07-19 10:35:17.706
Custom symbol settings values: enabled | 2019-07-19 10:35:17.706
Chart Update Interval: 500 | 2019-07-19 10:35:17.706
Intraday Data Storage Time Unit: 0 | 2019-07-19 10:35:17.706
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-07-19 10:35:17.706
2019-07-19 10:35:17 Local computer time | 2019-07-19 10:35:17.706
2019-07-19 17:35:17 Local computer time in UTC | 2019-07-19 10:35:17.706
2019-07-19 10:35:17 Local computer time in SC Time Zone | 2019-07-19 10:35:17.706
2019-07-18 18:26:50 Server time in UTC | 2019-07-19 10:35:17.706
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-07-19 10:35:17.706
Program path: C:\SierraChart\ | 2019-07-19 10:35:17.706
Data Files path: C:\SierraChart\Data\ | 2019-07-19 10:35:17.706
OS Version Number: 10.0 | 2019-07-19 10:35:17.707
Locale Setting: C | 2019-07-19 10:35:17.707
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-07-19 10:35:17.707
File >> Disconnect selected. | 2019-07-19 10:35:22.427
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2019-07-19 10:35:22.428
Rithmic Trading | Disconnected. | 2019-07-19 10:35:22.438
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (1) | Creating socket. Using TLS 1.2. | 2019-07-19 10:35:44.066
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 11. | 2019-07-19 10:35:44.066
Current selected Data/Trading service: SC Data - All Services | 2019-07-19 10:35:44.066
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (1) | Connecting to IP: 46.4.97.203. | 2019-07-19 10:35:44.067
DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-07-19 10:35:46.515 *
DTC Client socket (2) | Socket gracefully closed by remote side. | 2019-07-19 10:35:46.515
DTC Client socket (2) | Closed. | 2019-07-19 10:35:46.515
SC Data - All Services | Connected to data server. | 2019-07-19 10:35:47.051
SC Data - All Services | Starting real-time market data updates for: ESU9-CME. ID: 1 | 2019-07-19 10:35:47.181
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESU9-CME | 2019-07-19 10:35:47.181
SC Data - All Services | Requesting security definition data for: ESU9-CME. ID: 1 | 2019-07-19 10:35:47.181
No historical data client is currently set to download historical Intraday data for ESU9-CME. | 2019-07-19 10:35:47.181
Real-time Intraday chart data file updates started for ESU9-CME | 2019-07-19 10:35:47.181
Intraday chart data file opened for ESU9-CME | 2019-07-19 10:35:47.181
Symbol settings MD5 received. Request ID: 11. | 2019-07-19 10:35:47.782
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (2) | Creating socket. Using TLS 1.2. | 2019-07-19 10:35:47.782
Requested symbol settings for service code scdataallservices. Request ID: 12. | 2019-07-19 10:35:47.782
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (2) | Connecting to IP: 46.4.97.203. | 2019-07-19 10:35:47.783
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (1) | Shutdown started. Waiting for graceful close. | 2019-07-19 10:35:48.024
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (1) | Socket gracefully closed by remote side. | 2019-07-19 10:35:48.196
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (1) | Closed. | 2019-07-19 10:35:48.196
Requesting market depth updates for: ESU9-CME if supported. | 2019-07-19 10:35:52.055
Separate subscription for market depth updates not supported. ESU9-CME | 2019-07-19 10:35:52.055
Symbol settings received. Request ID: 12. | 2019-07-19 10:35:52.205
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (2) | Shutdown started. Waiting for graceful close. | 2019-07-19 10:35:52.617
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (2) | Socket gracefully closed by remote side. | 2019-07-19 10:35:52.780
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (2) | Closed. | 2019-07-19 10:35:52.780
[2019-07-19 19:17:52]
In this particular case the problem is with the symbol. It is not correct.
ESU9-CME needs to be ESU19.
Edit >> Translate Symbols To Current Service will change it. If not let us know.
