Date/Time: Wed, 23 Sep 2026 08:10:18 +0000
How can I filter the actual numbers on the number bars study?
View Count: 2039
| [2019-07-17 16:38:13] |
| User350051 - Posts: 16 |
Sorry new b question. I would like to filter the actual numbers on the number bars study, not the trades or volumes itself that comprise them. Is there a way to do this and/or highlight above a certain value. Is there a way to set an alert? Thanks
| [2019-07-17 21:53:33] |
| John - SC Support - Posts: 47980 |
We are not certain we fully understand the initial question of filtering the numbers, but if you are asking to only display certain values, then no, this is not directly supported. But, what you can do is to use the Text Coloring Method setting to control the coloring for the numbers, and then anything that is in a certain range could have the color set to the same as the background. Note that this is the same for highlighting above a certain value. We have attached a Study Collection that has a Numbers Bars study that displays Total Volume numbers in Column 1 and the Volume Profile in Column 2. If a volume is below 500, it is drawn as black, which is the same as my background color (you may need to change this). If a number is greater than 1500, then it is drawn as either Purple or Orange, depending on whether it is an up or down bar. This should help you configure the display as you want it. Refer to the following for how to use a Study Collection provided by Support: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-07-18 01:49:43] |
There is also this Input with the Numbers Bars study: Numbers Bars: Bid/Ask Volume Text Threshold Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-18 01:49:53
| [2019-07-18 14:55:01] |
Thanks is there a way I can set an alert by chance when a value on number bar is above certain amount?
| [2019-07-18 22:24:18] |
Not from within the Numbers Bars study, as the values are not directly available from there. The only way to do this would be to use this particular study: Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-18 22:24:37
