Date/Time: Mon, 14 Sep 2026 00:17:27 +0000
data connection
View Count: 890
| [2019-07-17 16:17:24] |
| jy - Posts: 6 |
I noticed that I am getting delayed quotes for NYSE and NASDAQ stock quotes. I am all payed up. What am I doing wrong? Thanks |
| [2019-07-17 16:28:07] |
Select Global Settings >> Symbol Settings. Uncheck Use Custom Symbol Settings Values. Press OK. Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers This should resolve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-17 16:28:41
| [2019-07-17 16:43:38] |
| jy - Posts: 6 |
What does the $35 per month fee cover when you subscribe to 100 real time symbols ? Does this mean CME symbols or US Equities symbols? DO you have to separately pay for US Equities to get real time stock quotes ? Is there any documentation where it breaks down exactly what each category of subscription gets you ? THank you Date Time Of Last Edit: 2019-07-17 16:45:07
| [2019-07-17 22:12:45] |
| John - SC Support - Posts: 47854 |
Refer to the following for the symbol limits: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SymbolLimits All of the data from the Sierra Chart Exchange Data Feed works the same way - first you need to pay for the Real-Time connection, which in your case is 35 USD per month for 100 symbols. Then you need to activate the exchanges for which you want to receive the real-time data, which in your case is the Full CME Group with Market Depth at 15.75 USD per month and the US Equities at 10.50 USD per month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
