Date/Time: Sat, 01 Feb 2025 12:48:01 +0000
Trade Window Configuration Keyboard shortcut
View Count: 2009
[2019-07-17 16:04:30] |
Mauro - Posts: 45 |
Hello, I am trying to setup a keyboard shortcut for my "trade window configuration" but I can't make it work. After saving the configuration I attached a shortcut key to it but when I try the shortcut nothing happens. The configuration in the trade window doesn't change. Any help appreciated. Thank you Mauro |
[2019-07-18 08:28:25] |
Make sure you enable keyboard shortcuts for the chart as documented here: Basic Trading and the Trade Window: Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-18 08:28:31
[2019-07-18 13:28:05] |
Mauro - Posts: 45 |
Thank you for the response, I did enable the trade shortcuts and I think I followed the instructions correctly. Maybe I am missing something. Other shortcuts in the trade window work, it is just the configuration. I also tried to rename the configuration "Configuration 1" but nothing. |
[2019-07-19 04:47:53] |
Follow-through the instructions we prepared here for this: Basic Trading and the Trade Window: Keyboard Shortcuts for Trade Window Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-19 13:28:50] |
Mauro - Posts: 45 |
Yes, now I undestood the process and it works! Thank you Mauro |
