Date/Time: Sat, 01 Feb 2025 13:02:46 +0000
Transperancy level of study subgraph
View Count: 533
[2019-07-16 15:59:58] |
User97684 - Posts: 136 |
Hi, PLs help - is it possible to adjust the transperancy level of the line, in the Line Study, Many thanks |
Transperancy_level_on_Line_study.png / V - Attached On 2019-07-16 15:59:34 UTC - Size: 142.27 KB - 231 views |
[2019-07-16 17:32:55] |
No this is not supported for that particular Draw Style. You would need to use one of the Transparent styles which would require two Subgraphs.
