Date/Time: Thu, 06 Mar 2025 15:47:48 +0000
Cannot Adjust Ticks Per Volume Bar on VbP Indicator
View Count: 1017
[2019-07-16 15:34:52] |
User750602 - Posts: 3 |
Hello, I have Sierra Chart package 3 and I am trying to adjust the "Ticks Per Volume Bar" setting from 5 to 1 on the "Volume By Price" indicator. However, the setting immediately reverts back to a value of 5 when I try to change it. Is there something else I need to change or is this just a limitation of package 3? Thank you! Paul |
[2019-07-16 18:09:41] |
This is not related to the package you are on. Refer to the last paragraph of this section for the reason why this is happening: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-22 21:27:33] |
Perfect! Thank you!
