Date/Time: Sun, 24 Nov 2024 18:56:27 +0000
Connection Problems
View Count: 1509
[2013-12-03 15:26:17]
fobglobal - Posts: 51
Hi:
I have lost the connection twice this morning, in order to resolve the issue, I need to close Sierra and the Transact Bridge then I login again. It works for some time and then the problem again. Please let me know what is happening.
Software version: 1056 | 2013-12-03 08:34:28
Enabled for: Sierra Chart Historical Data Service. | 2013-12-03 08:34:28
Active service: TransAct | 2013-12-03 08:34:28
Time Zone: -06:00:00 (MXST-06MXDT+01,M4.1.0/02:00,M10.5.0/02:00) | 2013-12-03 08:34:28
2013-12-03 08:34:28 Local computer clock time | 2013-12-03 08:34:28
2013-12-03 14:34:28 GMT time | 2013-12-03 08:34:28
2013-12-03 08:34:28 Time zone adjusted time | 2013-12-03 08:34:28
Time difference to server time: 0 seconds. | 2013-12-03 08:34:28
Program path: C:\SierraChart\SierraChartTransActMA\ | 2013-12-03 08:34:28
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2013-12-03 08:34:28
OS Version Number: 5.1 | 2013-12-03 08:34:28
Checking for new symbol settings for ta | 2013-12-03 08:34:28
The Chartbook file is not a valid Chartbook. File: C:\SierraChart\SierraChartTransActMA\Data\Infinity Chart Startup.cht | 2013-12-03 08:34:28
HD Request # 2 - Downloading Intraday chart data for 6EZ3 to the file 6EZ3.scid. Service: ta | 2013-12-03 08:34:29
HD Request # 2 - Last Date-Time in file: 2013-12-03 08:30:45.0 | 2013-12-03 08:34:29
HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2013-12-03 08:34:29
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-03 08:34:29
The network socket is connected. | 2013-12-03 08:34:29
HD Request # 2 - Sending historical data logon request message. | 2013-12-03 08:34:29
HD Request # 2 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:29
HD Request # 2 - Decompressing data. | 2013-12-03 08:34:30
The network socket for historical data has been closed. | 2013-12-03 08:34:30
HD Request # 2 - Historical data for 6EZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-03 08:34:30
HD Request # 2 - Received 1 record and wrote 0 records for 6EZ3 | 2013-12-03 08:34:30
HD Request # 2 - Intraday download COMPLETE for 6EZ3 | 2013-12-03 08:34:30
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2012-11-29 08:00:00. Next Bar Date Time: 2012-11-29 07:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2012-12-21 08:15:00. Next Bar Date Time: 2012-12-21 08:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-01-09 11:00:00. Next Bar Date Time: 2013-01-09 10:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-01-24 08:45:00. Next Bar Date Time: 2013-01-24 08:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-02-01 10:00:00. Next Bar Date Time: 2013-02-01 09:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-02-15 08:45:00. Next Bar Date Time: 2013-02-15 08:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-01 09:15:00. Next Bar Date Time: 2013-03-01 08:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-08 07:30:00. Next Bar Date Time: 2013-03-08 07:15:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-08 09:45:00. Next Bar Date Time: 2013-03-08 09:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-18 07:15:00. Next Bar Date Time: 2013-03-18 06:15:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-03-20 08:15:00. Next Bar Date Time: 2013-03-20 08:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-04-04 09:45:00. Next Bar Date Time: 2013-04-04 09:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-04-25 09:00:00. Next Bar Date Time: 2013-04-25 08:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-05-08 10:30:00. Next Bar Date Time: 2013-05-08 10:15:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-05-20 08:45:00. Next Bar Date Time: 2013-05-20 08:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-05-23 08:45:00. Next Bar Date Time: 2013-05-23 08:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-05-29 12:00:00. Next Bar Date Time: 2013-05-29 11:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-06-17 09:15:00. Next Bar Date Time: 2013-06-17 09:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-06-24 08:30:00. Next Bar Date Time: 2013-06-24 08:15:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-07-11 09:30:00. Next Bar Date Time: 2013-07-11 08:45:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\DXZ3.scid | 2013-12-03 08:34:32
HD Request # 3 - Downloading Historical Daily chart data for E6#. Starting date: 2013-12-02. Service: ta | 2013-12-03 08:34:33
HD Request # 3 - Requesting historical Daily Continuous data for E6Z10 starting at 2013-12-01 | 2013-12-03 08:34:33
HD Request # 3 - Receiving historical Daily data for E6# starting at 2013-12-02 | 2013-12-03 08:34:33
Writing historical Daily data for E6# to the file E6#.dly | 2013-12-03 08:34:33
HD Request # 3 - Received 2 records from 2013-12-02 00:00:00 to 2013-12-03 00:00:00 (2.0 days) and wrote 2 records for E6# | 2013-12-03 08:34:33
HD Request # 3 - Daily download COMPLETE for E6# | 2013-12-03 08:34:33
HD Request # 4 - Downloading Historical Daily chart data for DX#. Starting date: 2013-12-02. Service: ta | 2013-12-03 08:34:34
HD Request # 4 - Requesting historical Daily Continuous data for DXZ10 starting at 2013-12-01 | 2013-12-03 08:34:34
HD Request # 5 - Downloading Intraday chart data for 6BZ3 to the file 6BZ3.scid. Service: ta | 2013-12-03 08:34:34
HD Request # 5 - Last Date-Time in file: 2013-12-03 08:30:30.0 | 2013-12-03 08:34:34
HD Request # 5 - Using server: ds4.sierracharts.com port 10149 | 2013-12-03 08:34:34
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-03 08:34:34
The network socket is connected. | 2013-12-03 08:34:34
HD Request # 5 - Sending historical data logon request message. | 2013-12-03 08:34:34
HD Request # 4 - Receiving historical Daily data for DX# starting at 2013-12-02 | 2013-12-03 08:34:34
Writing historical Daily data for DX# to the file DX#.dly | 2013-12-03 08:34:34
HD Request # 4 - Received 2 records from 2013-12-02 00:00:00 to 2013-12-03 00:00:00 (2.0 days) and wrote 2 records for DX# | 2013-12-03 08:34:34
HD Request # 4 - Daily download COMPLETE for DX# | 2013-12-03 08:34:34
HD Request # 6 - Downloading Historical Daily chart data for B6#. Starting date: 2013-12-02. Service: ta | 2013-12-03 08:34:34
HD Request # 6 - Requesting historical Daily Continuous data for B6Z10 starting at 2013-12-01 | 2013-12-03 08:34:34
HD Request # 5 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:34
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 08:34:34
HD Request # 6 - Receiving historical Daily data for B6# starting at 2013-12-02 | 2013-12-03 08:34:34
Writing historical Daily data for B6# to the file B6#.dly | 2013-12-03 08:34:34
HD Request # 6 - Received 2 records from 2013-12-02 00:00:00 to 2013-12-03 00:00:00 (2.0 days) and wrote 2 records for B6# | 2013-12-03 08:34:34
HD Request # 5 - Decompressing data. | 2013-12-03 08:34:34
The network socket for historical data has been closed. | 2013-12-03 08:34:34
HD Request # 6 - Daily download COMPLETE for B6# | 2013-12-03 08:34:35
HD Request # 5 - Historical data for 6BZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-03 08:34:35
HD Request # 5 - Received 1 record and wrote 0 records for 6BZ3 | 2013-12-03 08:34:35
HD Request # 5 - Intraday download COMPLETE for 6BZ3 | 2013-12-03 08:34:35
HD Request # 7 - Downloading Historical Daily chart data for ES#. Starting date: 2013-12-02. Service: ta | 2013-12-03 08:34:35
HD Request # 7 - Requesting historical Daily Continuous data for ESZ10 starting at 2013-12-01 | 2013-12-03 08:34:35
HD Request # 8 - Downloading Intraday chart data for ESZ3 to the file ESZ3.scid. Service: ta | 2013-12-03 08:34:35
HD Request # 8 - Last Date-Time in file: 2013-12-03 08:30:45.0 | 2013-12-03 08:34:35
HD Request # 8 - Using server: ds3.sierracharts.com port 10149 | 2013-12-03 08:34:35
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-03 08:34:35
The network socket is connected. | 2013-12-03 08:34:35
HD Request # 8 - Sending historical data logon request message. | 2013-12-03 08:34:35
HD Request # 7 - Receiving historical Daily data for ES# starting at 2013-12-02 | 2013-12-03 08:34:35
Writing historical Daily data for ES# to the file ES#.dly | 2013-12-03 08:34:35
HD Request # 7 - Received 2 records from 2013-12-02 00:00:00 to 2013-12-03 00:00:00 (2.0 days) and wrote 2 records for ES# | 2013-12-03 08:34:35
HD Request # 7 - Daily download COMPLETE for ES# | 2013-12-03 08:34:35
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 08:34:35
Transact DTC: Connected to server. | 2013-12-03 08:34:35
DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-03 08:34:35
DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-03 08:34:35
Transact DTC: Sending logon request message. | 2013-12-03 08:34:35
HD Request # 8 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:36
HD Request # 8 - Decompressing data. | 2013-12-03 08:34:36
HD Request # 8 - Historical data for ESZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-03 08:34:36
The network socket for historical data has been closed. | 2013-12-03 08:34:36
HD Request # 8 - Received 1 record and wrote 0 records for ESZ3 | 2013-12-03 08:34:36
HD Request # 8 - Intraday download COMPLETE for ESZ3 | 2013-12-03 08:34:36
HD Request # 9 - Downloading Intraday chart data for DXZ3 to the file DXZ3.scid. Service: ta | 2013-12-03 08:34:36
HD Request # 9 - Last Date-Time in file: 2013-12-03 08:30:40.0 | 2013-12-03 08:34:36
HD Request # 9 - Using server: ds5.sierracharts.com port 10149 | 2013-12-03 08:34:36
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-03 08:34:36
The network socket is connected. | 2013-12-03 08:34:36
HD Request # 9 - Sending historical data logon request message. | 2013-12-03 08:34:36
HD Request # 9 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:36
HD Request # 9 - Error downloading historical Intraday data for DXZ3. Symbol not allowed. | 2013-12-03 08:34:36
HD Request # 9 - Received 0 records and wrote 0 records for DXZ3 | 2013-12-03 08:34:36
HD Request # 9 - Intraday download COMPLETE for DXZ3 | 2013-12-03 08:34:36
Chart #9 has tagged chart #10 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #9 has tagged chart #12 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #9 has tagged chart #13 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #9 has tagged chart #8 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #8 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #12 has tagged chart #13 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #12 has tagged chart #16 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #12 has tagged chart #8 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #16 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #10 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:37
Chart #13 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:38
Chart #8 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:39
Chart #8 has tagged chart #15 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:39
Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:39
Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-03 08:34:47
Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-03 08:34:47
Transact Futures - Successfully connected. Operation Successful. | 2013-12-03 08:34:47
Transact DTC - Starting real-time market data updates for: 6EZ3 | 2013-12-03 08:34:47
HD Request # 10 - Downloading Intraday chart data for 6EZ3 to the file 6EZ3.scid. Service: ta | 2013-12-03 08:34:47
HD Request # 10 - Last Date-Time in file: 2013-12-03 08:30:45.0 | 2013-12-03 08:34:47
HD Request # 10 - Using server: ds4.sierracharts.com port 10149 | 2013-12-03 08:34:47
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-03 08:34:47
The network socket is connected. | 2013-12-03 08:34:47
HD Request # 10 - Sending historical data logon request message. | 2013-12-03 08:34:47
HD Request # 10 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:47
HD Request # 10 - Decompressing data. | 2013-12-03 08:34:47
HD Request # 10 - Receiving Intraday data for 6EZ3 starting at 2013-12-03 08:30:45 | 2013-12-03 08:34:47
HD Request # 10 - Timestamp of first Intraday data file record written: 2013-12-03 08:30:46 | 2013-12-03 08:34:47
The network socket for historical data has been closed. | 2013-12-03 08:34:47
HD Request # 10 - Received 488 records from 2013-12-03 08:30:45 to 2013-12-03 08:34:45 (4.0 minutes) and wrote 487 records for 6EZ3 | 2013-12-03 08:34:47
HD Request # 10 - Intraday download COMPLETE for 6EZ3 | 2013-12-03 08:34:47
Real-time Intraday chart data file updates started for 6EZ3 | 2013-12-03 08:34:47
Transact DTC - Starting real-time market data updates for: DXZ3 | 2013-12-03 08:34:47
Transact DTC - Starting real-time market data updates for: ESZ3 | 2013-12-03 08:34:47
Chart #9 has tagged chart #10 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #11 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #12 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #13 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #15 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #16 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #9 has tagged chart #8 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #10 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Transact DTC - Starting real-time market data updates for: 6BZ3 | 2013-12-03 08:34:48
HD Request # 11 - Downloading Intraday chart data for 6BZ3 to the file 6BZ3.scid. Service: ta | 2013-12-03 08:34:48
HD Request # 11 - Last Date-Time in file: 2013-12-03 08:30:30.0 | 2013-12-03 08:34:48
HD Request # 11 - Using server: ds3.sierracharts.com port 10149 | 2013-12-03 08:34:48
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-03 08:34:48
The network socket is connected. | 2013-12-03 08:34:48
HD Request # 11 - Sending historical data logon request message. | 2013-12-03 08:34:48
Chart #13 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
HD Request # 11 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:48
Chart #8 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
HD Request # 11 - Decompressing data. | 2013-12-03 08:34:48
HD Request # 11 - Receiving Intraday data for 6BZ3 starting at 2013-12-03 08:30:30 | 2013-12-03 08:34:48
HD Request # 11 - Timestamp of first Intraday data file record written: 2013-12-03 08:30:46 | 2013-12-03 08:34:48
The network socket for historical data has been closed. | 2013-12-03 08:34:48
Chart #8 has tagged chart #15 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
HD Request # 11 - Received 160 records from 2013-12-03 08:30:30 to 2013-12-03 08:34:41 (4.2 minutes) and wrote 159 records for 6BZ3 | 2013-12-03 08:34:48
HD Request # 11 - Intraday download COMPLETE for 6BZ3 | 2013-12-03 08:34:48
Real-time Intraday chart data file updates started for 6BZ3 | 2013-12-03 08:34:48
HD Request # 12 - Downloading Intraday chart data for ESZ3 to the file ESZ3.scid. Service: ta | 2013-12-03 08:34:48
HD Request # 12 - Last Date-Time in file: 2013-12-03 08:30:45.0 | 2013-12-03 08:34:48
HD Request # 12 - Using server: ds5.sierracharts.com port 10149 | 2013-12-03 08:34:48
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-03 08:34:48
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #12 has tagged chart #13 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #12 has tagged chart #15 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #12 has tagged chart #16 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #12 has tagged chart #8 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
Chart #11 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
HD Request # 12 - Sending historical data logon request message. | 2013-12-03 08:34:48
HD Request # 12 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:48
HD Request # 12 - Decompressing data. | 2013-12-03 08:34:48
HD Request # 12 - Receiving Intraday data for ESZ3 starting at 2013-12-03 08:30:45 | 2013-12-03 08:34:48
HD Request # 12 - Timestamp of first Intraday data file record written: 2013-12-03 08:30:46 | 2013-12-03 08:34:48
Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:48
The network socket for historical data has been closed. | 2013-12-03 08:34:49
HD Request # 12 - Received 11117 records from 2013-12-03 08:30:45 to 2013-12-03 08:34:48 (4.1 minutes) and wrote 11069 records for ESZ3 | 2013-12-03 08:34:49
HD Request # 12 - Intraday download COMPLETE for ESZ3 | 2013-12-03 08:34:49
Real-time Intraday chart data file updates started for ESZ3 | 2013-12-03 08:34:49
Added 111 Time and Sales records to Intraday data file for ESZ3 after download. | 2013-12-03 08:34:49
HD Request # 13 - Downloading Intraday chart data for DXZ3 to the file DXZ3.scid. Service: ta | 2013-12-03 08:34:49
HD Request # 13 - Last Date-Time in file: 2013-12-03 08:30:40.0 | 2013-12-03 08:34:49
HD Request # 13 - Using server: ds4.sierracharts.com port 10149 | 2013-12-03 08:34:49
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-03 08:34:49
Chart #16 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:49
The network socket is connected. | 2013-12-03 08:34:49
HD Request # 13 - Sending historical data logon request message. | 2013-12-03 08:34:49
HD Request # 13 - Requesting up to 93 days of Intraday data. Record interval: 0 | 2013-12-03 08:34:50
Chart #13 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:50
HD Request # 13 - Decompressing data. | 2013-12-03 08:34:50
HD Request # 13 - Receiving Intraday data for DXZ3 starting at 2013-12-03 08:30:41 | 2013-12-03 08:34:50
HD Request # 13 - Timestamp of first Intraday data file record written: 2013-12-03 08:30:41 | 2013-12-03 08:34:50
The network socket for historical data has been closed. | 2013-12-03 08:34:50
HD Request # 13 - Received 110 records from 2013-12-03 08:30:41 to 2013-12-03 08:34:40 (4.0 minutes) and wrote 110 records for DXZ3 | 2013-12-03 08:34:50
HD Request # 13 - Intraday download COMPLETE for DXZ3 | 2013-12-03 08:34:50
Real-time Intraday chart data file updates started for DXZ3 | 2013-12-03 08:34:50
Chart #8 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:50
Chart #8 has tagged chart #15 for full recalculation. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:50
Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EURO 6EZ3 Trading Dic2013 V1.cht | 2013-12-03 08:34:50
The data feed was lost. There was no activity for at least 60.0 seconds. | 2013-12-03 09:09:53
Connection to the external service has been lost. | 2013-12-03 09:09:53
Transact Futures: Disconnected from the server. | 2013-12-03 09:09:53
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:09:53
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:09:54
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:09:55
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:09:56
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:09:56
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:09:56
Transact DTC: Disconnected from the server. | 2013-12-03 09:09:57
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:09:57
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:09:58
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:09:59
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:00
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:00
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:00
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:00
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:00
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:01
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:02
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:03
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:03
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:03
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:03
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:03
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:04
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:05
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:06
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:06
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:06
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:06
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:06
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:07
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:08
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:09
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:09
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:09
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:09
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:09
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:10
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:11
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:12
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:12
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:12
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:12
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:12
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:13
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:14
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:15
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:15
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:15
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:15
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:15
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:16
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:17
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:18
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:18
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:18
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:18
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:18
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:19
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:20
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:21
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:21
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:21
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:21
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:21
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:22
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:23
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:24
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:24
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:24
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:24
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:24
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:25
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:26
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:27
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:27
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:27
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:27
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:27
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:10:28
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:10:29
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:10:30
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:10:30
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:10:30
Transact DTC: Disconnected from the server. | 2013-12-03 09:10:30
Will reconnect to the server in 35.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:10:30
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:11:05
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:11:06
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:11:07
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:11:07
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:11:07
Transact DTC: Disconnected from the server. | 2013-12-03 09:11:07
Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:11:07
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:11:47
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:11:48
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:11:49
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:11:49
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:11:49
Transact DTC: Disconnected from the server. | 2013-12-03 09:11:49
Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:11:49
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:12:29
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:12:30
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:12:31
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:12:31
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:12:31
Transact DTC: Disconnected from the server. | 2013-12-03 09:12:31
Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:12:31
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:13:16
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:13:17
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:13:18
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:13:18
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:13:18
Transact DTC: Disconnected from the server. | 2013-12-03 09:13:18
Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:13:18
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:14:03
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:14:04
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:14:05
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:14:05
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:14:05
Transact DTC: Disconnected from the server. | 2013-12-03 09:14:05
Will reconnect to the server in 50.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:14:05
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:14:55
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:14:56
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:14:57
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:14:57
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:14:57
Transact DTC: Disconnected from the server. | 2013-12-03 09:14:57
Will reconnect to the server in 50.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:14:57
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:15:47
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:15:49
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:15:50
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:15:50
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:15:50
Transact DTC: Disconnected from the server. | 2013-12-03 09:15:50
Will reconnect to the server in 55.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:15:50
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:16:45
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:16:46
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:16:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:16:47
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:16:47
Transact DTC: Disconnected from the server. | 2013-12-03 09:16:47
Will reconnect to the server in 55.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:16:47
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:17:42
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:17:43
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:17:44
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:17:44
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:17:44
Transact DTC: Disconnected from the server. | 2013-12-03 09:17:44
Will reconnect to the server in 60.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:17:44
The above has been sent to support. | 2013-12-03 09:18:13
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\SierraChartTransActMA\Data\MessageLogAnalysis.htm | 2013-12-03 09:18:14
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:18:44
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:18:45
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:18:46
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:18:46
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:18:46
Transact DTC: Disconnected from the server. | 2013-12-03 09:18:46
Will reconnect to the server in 60.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:18:46
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:19:46
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:19:47
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:19:48
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:19:48
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:19:48
Transact DTC: Disconnected from the server. | 2013-12-03 09:19:48
Will reconnect to the server in 65.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:19:48
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:20:53
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:20:54
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:20:55
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:20:55
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:20:55
Transact DTC: Disconnected from the server. | 2013-12-03 09:20:55
Will reconnect to the server in 65.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:20:55
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:22:00
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:22:01
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:22:02
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:22:02
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:22:02
Transact DTC: Disconnected from the server. | 2013-12-03 09:22:02
Will reconnect to the server in 70.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:22:02
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:23:12
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:23:13
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:23:14
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:23:14
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:23:14
Transact DTC: Disconnected from the server. | 2013-12-03 09:23:14
Will reconnect to the server in 70.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:23:14
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:24:24
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:24:25
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:24:26
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:24:26
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:24:26
Transact DTC: Disconnected from the server. | 2013-12-03 09:24:26
Will reconnect to the server in 75.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:24:26
Transact DTC - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-12-03 09:25:41
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-03 09:25:42
Error received in OnConnect while connecting. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-12-03 09:25:43
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-03 09:25:43
To prevent further connection attempts, select File >> Disconnect. | 2013-12-03 09:25:43
Transact DTC: Disconnected from the server. | 2013-12-03 09:25:43
Will reconnect to the server in 75.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-03 09:25:43
[2013-12-03 18:00:31]
Are you able to connect now? If the data feed sometimes stops, then you should uncheck Use Mode 1 on the TransActBridge program that you can access through the system tray on your Windows taskbar.
After this reconnect to the data feed with File >> Disconnect and File >> Connect to Data Feed.
Date Time Of Last Edit: 2013-12-03 18:21:27
