Date/Time: Sat, 01 Feb 2025 12:39:13 +0000
Link existing chart to existing DOM
View Count: 1795
[2019-07-15 21:43:56] |
User247447 - Posts: 11 |
I just spent a few hours customizing my DOM settings, and I've enabled chart trading. I have tried linking the chart - and assigning it number 1. Is there a way that I can link this chart to the existing DOM, so I can press the M key and disable confirmations when moving existing orders on the chart? I've pressed F5 on the DOM, and made sure it was set to number 1 under Linking, as well as on the chart - but it's only applying the confirmation settings to the DOM when I move an order there. |
[2019-07-15 23:50:35] |
Please disregard - I have figured this out. Cheers
[2019-07-16 00:33:30] |
This is supported by linking the Trade Windows. The options available for linked charts are found in Chart >> Chart Settings >> Advanced Settings 2. Refer to the following regarding chart linking: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
