Date/Time: Sat, 01 Feb 2025 12:53:54 +0000
DOM - cannot change font color
View Count: 1166
[2019-07-15 19:05:20]
User247447 - Posts: 11
Hello - I'm able to customize my DOM to the earth's end, including adding columns and customizing fonts.
I am not using global settings for the DOM colors, but one issue that I am having is - I want to change the font color for Chart Text, and when I change it from Black to White, click Apply, then OK, it reverts back to Black.
I am able to change the font type and size, but the color is being stubborn.
I am essentially looking to make the DOM backgrounds primarily dark, with white text.
Any help is appreciated.
[2019-07-15 19:07:47]
Attached is currently what my DOM looks like - you can see I've changed the font size for the "Quote" column, as well as a bunch of other custom colors, however when I change this from Black to White, it does not apply the settings.
imagedom-sample.PNG / V - Attached On 2019-07-15 19:07:12 UTC - Size: 44.78 KB - 345 views
[2019-07-15 20:31:11]
You have to change the font colors through the Graphics Settings >> Colors and Widths tab:
Graphics Settings
The color setting within the Font Selector window is ignored.
Date Time Of Last Edit: 2019-07-15 20:31:21
[2019-07-16 00:22:02]
Thank you kindly - I must not have had enough coffee.
Cheers
