Date/Time: Sat, 19 Sep 2026 07:11:56 +0000
DOM graphics settings
View Count: 1154
| [2019-07-15 18:52:53] |
| User239125 - Posts: 3 |
Hi, I either inadvertantly did something or an update this morning made changes I am not aware of, but some of the colors I had set for various columns and text in a customized DOM are now different. The Dom is set to use the global graphics settings. When I try to change the colors to replicate what I used to have in the global graphics settings, on a few columns the changes don't go into effect, and on the market depth pulling / stacking columns, the box to click to enable a color is greyed out, not allowing me to make changes. How can I fix the DOM to bring the settings back to what I used to have? Thank you. |
| [2019-07-15 20:27:47] |
Are you referring to the color settings for the market depth pulling and stacking columns? , and on the market depth pulling / stacking columns, the box to click to enable a color is greyed out, This is because the color cannot be disabled. This is not a problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-15 20:27:54
| [2019-07-15 22:16:51] |
Yes, I apologize if I wasn't being clear. I have market depth pulling and stacking columns. One for the bid and one for the ask. The colors I had set it up with got changed. I am not sure what I did that changed them. When I went into the global graphics settings and tried to fix it, the changes I made wouldn't take. I tried multiple times. I found a work around after I posted. I recreated the DOM colors I had, using the graphics settings for the DOM itself and don't have it checked to use the global graphics settings anymore. It is working that way. Thanks. |
| [2019-07-17 04:38:59] |
Ok we would not expect any problem. So we will look into this.
