Date/Time: Sat, 01 Feb 2025 12:46:37 +0000
Setting the default TC# quick load number
View Count: 1663
[2019-07-15 15:21:59]
User957752 - Posts: 9
Hi All.
I have button to draw Volume profiles. I have 4 TC quick load settings created.
I want to change the default setting to TC1 when I choose the button. Currently it's set to TC3.
I've tried everything I can think of & can't change it from TC3 to TC1 when I choose the button.
Thanks.
[2019-07-15 20:15:42]
You can choose the current tool configuration for the active drawing tool through Tools >> Current Tool Configuration.
This will affect what particular configuration is selected when you go into the Tool Configuration window for the drawing tool.
Date Time Of Last Edit: 2019-07-15 20:16:27
[2019-07-16 14:12:04]
Thanks Support. I did not see that in the help docs ... & I would have never thought of that.
My interface logic was saying I should do it in the Tool Configuration window. I thought by choosing a TC# then pressing the "proper" button & closing the window would save my choice.
[2019-07-16 17:27:00]
This is documented here:
Chart Drawing Tools: Using Multiple Drawing Tool Configurations (Using Multiple Drawing Tool Configurations)
Date Time Of Last Edit: 2019-07-16 17:27:14
