Date/Time: Sat, 01 Feb 2025 13:00:59 +0000
no Bid Ask values on Chart DOM
View Count: 705
[2019-07-15 13:39:56] |
User98657 - Posts: 330 |
CAn you give me any clues as to why I wouldn't be seeing the Bid Ask values on my Chart DOM? I have them on one ES chart, but not on others. It is not a coloring issue. |
[2019-07-15 20:04:00] |
We are writing up some documentation on this and will have it out a little later today.
[2019-07-15 21:07:11] |
John - SC Support - Posts: 37656 |
Refer to this section of the documentation for troubleshooting Market Depth data not showing in the DOM: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
