Date/Time: Sat, 01 Feb 2025 12:47:20 +0000
Keeps logging into old data feed?
View Count: 541
[2019-07-15 15:12:09] |
It would seem as though your Rithmic username does not have any trading accounts assigned to it. Check with your broker on this. Do you just see one account listed on the Trade Window? If so, then your Rithmic username does not have the correct account assigned or any account assigned. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-15 15:12:37
