Date/Time: Sat, 01 Feb 2025 12:56:36 +0000
STUDIO BID E ASK
View Count: 745
[2019-07-15 06:50:28] |
cestolone - Posts: 2 |
hello I should create a study to have a line that represents me or every tick if the bid part or the ask part of the book is hit, or a suggestion on how to set up an existing study thanks
[2019-07-15 07:24:19] |
This is not clear specifically what you require.
[2019-07-15 18:39:11] |
John - SC Support - Posts: 37656 |
One way to do this, where whichever one is being hit will be highlighted, is to add the Recent Bid and Recent Ask DOM Columns, then enable the following two colors in Global Settings >> Graphics Settings: - Chart DOM Last Traded Bid Volume Background - Chart Dom Last Traded Ask Volume Background or, if using a Trading DOM, it would be under Chart >> Graphics Settings, and then the options would be: - Trade DOM Last Traded Bid Volume Background - Trade DOM Last Traded Ask Volume Background And ensure that this setting is NOT enabled in Trade >> Chart DOM Settings: - Display Both Last Traded Recent Bid and Ask Background Refer to the following for adding columns to the DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Refer to the following for the background colors: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Last Traded Recent Bid Volume Background And refer to the following for the setting to display both Last Traded Bid and Ask: Global Trade Settings Windows: Display Both Last Traded Recent Bid and Ask Background (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
